It's available on S|C ftp, in the spacef free plugins sub-folder.
It works with anything that accept audio modulation and audio gate triggers.
It was made for the Korg MS20-mini but works exactly the same with Ocean Swift Synthesis OS20.
It works also as a modulator for filters (for Modular Mixer v1 and v2) , modular patches and so on....
Find it here : https://spacef-devices.com/DOWNLOADS/Logiquencer.zip
I made a small video for it but it is pretty bad I think.... it's a bit out of sync and my haircut is awful.
https://www.youtube.com/watch?v=3gr6W_I ... e=youtu.be
Logiquencer freeware
- LOGIQUENCER.jpg (137.78 KiB) Viewed 29252 times
Re: Logiquencer freeware
Excellent news and thanks.
I have CF VCF In and CV Trigger In on my SE-02s.
This could be my way of trigger notes or patterns/ARPs/Songs from my K4 instead manually messing around.
The golden rule in performing is keep both hands on your keyboard/zones.
Video was fine, and your handsome as always.
Should use your profile on your gear.
Low angle shot like Mt. Rushmore....
Hi Jimmy, thanks
To work with CV it needs a audio to CV converters. I know that expert sleepers does 1 (the ES3 - adat to CV) for 8 CV.
Are there other ones ?
You don't need an audio to CV converter if the sound card outputs are "DC Coupled" (I think only RME does this), but I think there will also be latency.
Excellent thanks
iirc, it is MOTU that has DC-coupled outs (on most of their interfaces). Some RME interfaces have their headphone outs DC-coupled. There is a list somewhere on the expertsleepers website.spacef wrote:You don't need an audio to CV converter if the sound card outputs are "DC Coupled" (I think only RME does this), but I think there will also be latency.
andy
the lunatics are in the hall
My ADA8200s are modded by Black Lion Audio and have 16 x DC Coupled XLRs.
We’ll see...
We’ll see...
very interesting, i didn't know that company.
wow
abgefahren
really great stuff!
cheers ms20 lovers!
abgefahren
really great stuff!
cheers ms20 lovers!
Ok, now I'd like to ask, ReTrig Manual works, keyboard does not work. (xite-1)
...pci not used yet. did you notice that already?
ps.:
offset 32 works fine to convert bi2uni with -12db for fullrange control inside scope cv-toys
ps.:
I have just checked and it should work fine. I will check again tomorrow for exact version. Thanks for your patience.
NB : For CV are you talink about bipolar modulator ?
For info, the range of a 3 octave CV Signal (like the one you get by using Expert Sleepers ADAT to CV) is approx the range of the scope signal divided by 3 (approximately). To control the pitch of an oscillator over more than 3 octaves, then you would need to add several CV inputs and make them very precise (for ex, the 1st CV controls octave 0 to 3, and other CV controls octave 4 to 6 - then the work is to find the right method to add both signal so it stays in tune, which means that the second CV must be equal to 0 over the whole range of the first CV. This must be done "after" the Adat to CV conversion because it manages only 3 octaves "no matter what".
A total loss of time for scope though, people can buy a keystep keyboard second hand, it has a CV output and can play the full keyboard range.
For unipolar/bipolar, I confess I do not know what you are talking about
Here is a download for you
I just checked and it works fine with Keyboard retriggering. It is the latest version that I Have
he is about CV abusespacef wrote: Sat Dec 07, 2019 1:56 pm ... For unipolar/bipolar, I confess I do not know what you are talking about![]()
thx man, you make me happy \o/
