StemmiX - 8Ch Stem Mixer
mausmuso
Post by mausmuso »
Hi There,
I have put together a stem mixer for my own use.
You might find it useful as well.
It is heavy on DSP so those with PCI cards might find it limited in its use.
It does load on my Pular 2 card, but I think it would not do so on a Luna card.
Works fine on XITE-1.
There is an overview PDF included to help you understand what features are of the mixer.
I have not tested every last function to date, so if you find anything that needs work please let me know.
Hope you like it.
maus
Stemmix.zip
(2.52 MiB) Downloaded 299 times
Yogimeister
Re: StemmiX - 8Ch Stem Mixer
Post by Yogimeister »
WOW!
Looks amazing, kudos and thanks!
Will check it out...
Marco
Post by Marco »
:D A new mixer! Nice to make stem recordings. Thx
David
Post by David »
Thank you mausmuso
Cool look excellent device
mausmuso
Post by mausmuso »
Marco wrote::D A new mixer! Nice to make stem recordings. Thx
Hi There,
Actually it has been built to mix existing stems coming from another mixer or sequencer.
Maybe I should have included direct outs to record each stem?
Regards
maus
Marco
Post by Marco »
This would be a great idea! :D
You made a description of what your device can do! Very good!
David
Post by David »
mausmuso wrote: should have included direct outs to record each stem
Yes please, that would be a great addition
Post by JoPo »
Waow ! Excellent ! Thanks a lot !
guppy
Post by guppy »
Thank you ! :)
Early holiday gifts.
Thanks Mau.
Post by jksuperstar »
Does the interface use common controls shared across channels (midi)? In the way of select a channel, then modify the parameters. The interface looks like it, which is awesome!
Yogimeister
And so pretty ... :)
Btw - how doesl it behave in terms of
Latencies between the channels / busses?
(Do all channels have the same sample latency when no effects are used?
If there one, is it constant between sessions?)
Master Channel reminds of BX Digital Mono maker.
Nice package.
Seems you can use a few of these with not problems too.
Tie them all into a 6 x 2 config using collapsible Micro or Dynamic Mixer.
mausmuso
Post by mausmuso »
jksuperstar wrote:Does the interface use common controls shared across channels (midi)? In the way of select a channel, then modify the parameters. The interface looks like it, which is awesome!
No, the FX's for each channel is in fact a separate page.
I started down the common controls line but the switching got difficult.
I haven't given up on doing that at some stage but it needs work.
Regards
maus
mausmuso
Post by mausmuso »
Yogimeister wrote:And so pretty ... :)
I have not done any latency testing as yet.
I will try to set a test and see what we get.
maus
Yogimeister
maus
I will test it too one I install it (PCI cards) and let you know...
And thanks again! Awesome sauce!
