Micro ATX PCI expander
fokas
Post by fokas »
This just caught my attention. It can be Sata powered which seems promising but needs to be tested and will be an ergonomical wonder for a MicroATX in a ATX Case.
Re: Micro ATX PCI expander
I've been using Riser Cards and Ribbons for years.
Its how I have 1U PCs for Scope.
Using micro ATX too.
We don't need all of the excess slots and gunk on gaming boards.
panaman
Post by panaman »
looks like that sintech pcie to pci riser card.
did you get it to work?
with internal and external cards?
more than 3?
You need to ensure it’s the proper voltage conversion for 32 bit PCI Slots to function correctly.
But using one that would work would be a gold mine on Z97 boards.
No PCH Redirections, straight to the CPU.
ste
Post by ste »
dawman wrote: Fri Aug 18, 2017 2:45 pm I've been using Riser Cards and Ribbons for years.
hello,
i would be interested to give new life to my pulsarII card with a lot of synths purchased... is it possible to have more informations about your system? Components, motherboard, powersupply&1UCase and so on..
thanks!
ste
so far, there have been no good expanders that i have seen.
ste wrote: Wed Sep 12, 2018 5:50 am
hello,
thanks!
ste
Sure.
Supermicro CSE-512f-440B which is a 1U ATX Chassis
i7 4790k
ASRock anything Z or H97
32GBs Of DDR3 RAM
Samsung 850 Evo SSDs.
That’s about it.
ste
Post by ste »
wow! great! And you have a box for your scope through pciex-to-pci adapter, is it correct?
no, he has an XITE-1 which has a connector in a PCIE slot.
external PCI expansion boxes don't work well.
also, as you can see, he does not have a bunch of dsps inside there and he still needs to be aware of heat. 3 space minimum for a PCI card is a good idea.
ste
Post by ste »
garyb wrote: Thu Sep 13, 2018 9:03 pm no, he has an XITE-1 which has a connector in a PCIE slot.
i understand :( perhaps i will have no alternative to move to a bigger case, although it's heavier and bigger...
Thanks garyb and dawman!
ste
Janni
Post by Janni »
Try to get a refurbished/used HP workstation in a rackable case and use your scopecards as a standalone FX/Synth-unit.
I am using a xw6200 with winxp 32bit (about 160€) with a 14 and a 6 DSP card.
Each card has its own IRQ.
No VSTis, no sequencer, no ASIO-hassle... Just processing ADAT ins. Works perfect!!!
My OS is on a small SSD and booting it up takes just a few seconds.
https://support.hp.com/gb-en/document/c00215315
Yes, and there's this urban legend of running out of boards with PCI slots...
There is SO MUCH stuff available that you could still buy boards with twin PCI bussus (6 slots), some even new old stock :D
(recently found a German site with the most exotic collection I ever spotted online)
Of course such offers vary a lot (and naturally with time passing), but the sheer amount was stunning - and that was just 1 single online store.
Music Manic
Post by Music Manic »
garyb wrote: Wed Sep 12, 2018 8:58 am so far, there have been no good expanders that i have seen.
I was getting excited until I read that.
Music Manic
astroman wrote: Wed Sep 19, 2018 5:35 am Yes, and there's this urban legend of running out of boards with PCI slots...
Do you have any links for 3 PCI Mobos?
Music Manic
dawman wrote: Wed Sep 12, 2018 4:11 pm
hello,
thanks!
ste
Sure.
i7 4790k
32GBs Of DDR3 RAM
That’s about it.
A few of questions Jimmy:
1-how is that system for large sample libraries players like Kontakt.
2-can it be synced to another System’s Daw?
3-are there any accessories apart from xite that can send good quality audio outs to a scope pci system? Using it as a sampler so to speak?
It’s great for ASIO Sampled instruments.
Yes, with software like VEPro
Digital Audio is cheaper and easier to get high quality audio.
Get a used RME like a Ray Dat or even cheaper if possible.
It’s the quality of the drivers that makes RME, Lynx and Apogee better cards.
But you should try the onboard audio of the motherboard for shits and grins.
Who knows, it might work.
Everything gets better and smaller every cycle.
Good Luck Mate
Music Manic wrote: Thu Sep 20, 2018 7:17 pm
you probably mean 'modern' motherboards - sorry, I gave up on those long ago. Imho Dawman is the most reliable source in that domain as he still seems to ride the cutting edge of the wave with sustained endurance :D
I don't mind lack of CPU cycles and stick with classic boards and would receive Scope data via Adat on a modern, high power system (if in need).
