Multiple MIDI CC#s
Multiple MIDI CC#s
Even my Master MIDI Physis K4 sends 8 x CC#s simultaneously per controller, but not on the same MIDI Channel.
Case in point:
I want to modulate Cutoff and Sync amounts at the same time for a more pronounced Wah-Wah on my new SE-02 synth.
Physis allow 1 x CC# for cutoff.
I want Sync and Cutoff modulated at the same time as that Wah-Wah effect is vastly superior.
Scope Modular to the rescue.
I use the Expression Pedal, assign a CC#, then right click on Sharcs CC16 Master Fader.
Now when I start wah-wah'ing, I am modulating 2 x parameters.
MIDI form Physis k4 into Scope via MIDI Source Module, then out via XITE-1 MIDI Out into SE-02.
Store the preset so when the K4 sends a MIDI Program Change to the SE-02, Scope Modular changes accordingly.
No other apps do this. Bome Box + Translator Pro do, but that's hardware.
Its also a spare rig to use in case the PC crashes.
Re: Multiple MIDI CC#s
:o
Awesome !!!
Looks like you have rapid control over your expressions
