I need piano for STS
Talk about the STS series of Creamware samplers.
sandrob
Post by sandrob »
I need some free piano for STS sampler.
Can someone give me a download link?
Re: I need piano for STS
you can load any soundfont.
there are many, many soundfont pianos available. use google for "soundfonts piano"
sandrob
Post by sandrob »
Aha. Thanks :)
sandrob
Post by sandrob »
When I load a soundfont crash windows. Is this a known behavior, or maybe the samples are incorrect?
64bit?
no STS in 64bit, otherwise, it should load.
sandrob
Post by sandrob »
Yes 64
sandrob
Post by sandrob »
Can I use old Sample Player device?
I try to load soundfont but stuck.
no. the sample player part of Scope is almost 20 years old. there was no such thing as 64bit in those days.
there are free vst soundfont players....
sandrob
Post by sandrob »
garyb wrote: there are free vst soundfont players....
I need for S|C?
sandrob
Post by sandrob »
So, I need some polyphonic instrument (sampler or sinth) which I will add to the startup S|C project
so that I always have the piano sound on the keyboard (not the most high quality and can be mono) independently of VST.
Is there any idea?
for Scope? 32bit. if you aren't using sample based vstis, what in the world is the advantage to 64bit?
otherwise, there are stand alone sondfont players and samplers you could use. many are free or nearly free.
this one is free and works as stand alone or vst:
https://www.plogue.com/products/sforzando/
sandrob
Post by sandrob »
I don't need a VST instrument or stand alone!
I need polyphonic SCOPE SINT or SCOPE SAMPLE PLAYER (64bit) with piano sound?
It can be mono.
I would add this instrument to the startup Scope project, to have piano sound independent of Cubase.
Stand-alone versions of the VST instruments also don't come into consideration because they are taking the ASIO drivers that Cubase needs.
This piano is just a handy sound for me to give intonations to singers and players etc.
It is important for me to have piano sound on the keyboard all the time and the best solution is Scope (startup project),
I just have to find the right Scope instrument that will work steadily.
32bit, no problem.
there are ways to share the ASIO driver, if you must do 64bit.
you can also run the piano in another PC or laptop.
i know these aren't the answers you want, but they are answers that will work right now.
sandrob
Post by sandrob »
Thanks, Gary :)
I already found piano sound in BlueSynth which I can add to startup project but sound is not polyphonic.
Must be some polyphonic piano sound in some Scope synth? :/
if that will work, just change the number of voices on the Bluesynth.
check the manual about the configuration section\devices on the livebar.
to the lower right of the picture of the synth are two boxes. bottom one is for setting the number of voices and the one above sets the midi channel. just click and drag to change the setting and add the voices you need.
sandrob
Post by sandrob »
garyb wrote:if that will work, just change the number of voices on the Bluesynth.
Yes! That's it! :D
Thanks, Gary :)
sandrob
Post by sandrob »
I found even better piano sound on Lightwave synth and now finally I have "independent" piano sound on my mini keybord all the time from the moment I turn computer on. :)
I didn't use Pulsar's instruments for a long time and I forget that I can set the number of the voices :)
Thanks again :)
of course!
i'm glad you have what you need!
