iNsertMix
mausmuso
iNsertMix
Post by mausmuso »
Hi There,
Attached is a little plaything for those interested.
Stereo input (2 Fx inserts) - Inline inserts for left, right, mono , mid and side channels, all remixed to stereo output (2 Fx inserts).
Inline channels have Lo and Hi cuts and mute buttons.
There is also separate outputs for Mono, Mid and Side if you wish to use them.
I hope its useful for you
regards
maus
iNsertMix.zip
(356.11 KiB) Downloaded 372 times
David
Re: iNsertMix
Post by David »
Thank you very much :)
Re: iNsertMix
Love the idea.
Thanks Maus
Re: iNsertMix
Thanks. Nice device for the arsenal
Re: iNsertMix
This works great at older great sounding effects that get phasing in the AUX Channels.
So it's a phase alignment tool also.
Really brilliant idea Maus.
Where's your donate button?
FernandoHood
Re: iNsertMix
Post by FernandoHood »
Love the idea! this looks pretty cool! will try for sure.
Curious, what do you guys insert in the Mid n SIde sections? just EQ? Saturation?
Ocean Swift Synthesis - Scope 3rd Party Plugins
http://www.oceanswift.net
FernandoHood
http://www.fernandohood.com
Atom Sessions - Music
https://atomsessions.bandcamp.com/
FernandoHood
Re: iNsertMix
share some cool tricks/examples on how to get the most of this plugin
FernandoHood
Yogimeister
Re: iNsertMix
Post by Yogimeister »
Sweet !!!!
Kudos and thanks Maus!
mausmuso
Re: iNsertMix
Post by mausmuso »
Hi There
I have updated iNsertMix somewhat adding solo's for each channel and short delays can now be inserted.
Originally I envisaged that this plugin might be able to allow me to add reverb to side signals, whilst maintaining well defined mids.
It grew somewhat from this idea.
It has not been all that good at doing this so far but it has many other possibilities to explore.
Version 2 allows a some delay in each channel to straighten up stereo mixes, sorting out minor phase issues and delaying effects if needed, etc.
The solo function makes it a little easier to set things up.
Hope this is useful.
Regards maus
iNsertMix v2.zip
(500.49 KiB) Downloaded 283 times
Yogimeister
Re: iNsertMix
Cool ....
Btw - maybe now you can try to put reverb on the mid channel and then Haas delay the output to become side information ....
(I have a "Reverbed Techno kick" effect in mind) ;)
And Thanks again !
Marco
Re: iNsertMix
Post by Marco »
You are the hero of my day, thx
Yogimeister
Re: iNsertMix
P.S.
Gating or sidechaining the reverb after the Hass delay will make the "Hassiness" less noticeable ;)
FernandoHood
Re: iNsertMix
nice! love the new delay per ch Feature
FernandoHood
Re: iNsertMix
Well I was inserting Delays now I just run my SE-02 into this.
Since it's a recreation of the Moog Ladder Filter and exactly like it, higher resonance settings sadly attenuate the volume drastically.
Linked fader on the iNsert Mix make it my perfect SE-02 Sub mixer now.
Cranking up the faders and adjusting the rest of the volumes per preset is easy.
Thanks Mau.
