E-Mixers
roy thinnes
E-Mixers
Post by roy thinnes »
Springtime - Mixertime!
Actually it's a pack of three mixers (E-Mix12m, 16m, 16s), and a Master mixer.
Select the mixer types you need (mono or stereo, EQ or not), and connect them to the E-Mix Master.
Aux, Busses and Mutegroups (if wanted) have to be connected too.
Download: here
btw. all channels are on dsp, just EQs, Aux and Busses can be (and are by default) switched off.
Re: E-Mixers
yay!!! I was really bored today now I have something new to play with. Thanks Roy
Marco
Re: E-Mixers
Post by Marco »
Wowowowow! This is the most beautiful mixer ever! Thank you for your work! :D :D :D
I must try this out!
roy thinnes
Re: E-Mixers
sorry but I forgot to mention that it's made on a Pci system.
It's quite possible that it's unusable for the xite :roll:
Re: E-Mixers
Post by JoPo »
Wow ! Roy ! This mixer concept is awesome ! :wink: Thank yooOOoo !
Hep ! Xite users !
Works very well on my xited system untill ... I reload the project. Then it crashes when reloading. 2 E-Mix16s + 1 E-Mix Master in my project... Do you experiment the same issue, xite users ?? :-?
Please tell me ! I'm fed up with STM, the only mixers that work perfectly on my system ! I want to use those E-ones ! What is the secret ?
Re: E-Mixers
All seems to be working fine here so far. Project recallable. Very nice work Roy not too heavy on the DSP and lots of routing options, thanks a bunch this is just what I need
ronnie
Re: E-Mixers
Post by ronnie »
Looks yummy! Many thanks.
Re: E-Mixers
Post by JoPo »
yayajohn wrote:All seems to be working fine here so far. Project recallable. Very nice work Roy not too heavy on the DSP and lots of routing options, thanks a bunch this is just what I need
Me too ! Those mixers are what I neeeEEEeeed !
After rebuilding my template by delting STM, close & reload the project (which I didn't do on the first test) in order to let the xite ardering dsp's better than simply deleting STM & loading Emixers on the same session, I'm able to load the template with Emixers without crashing.
For the moment, I can't make more test, I'm working on a project that would take half a day to change mixer. But for my next new project, I'll use this new Emixer template. I know that Roy's mixers are lighter for dsp's than STM ! I really wish to use Emixers ! Aaarrrr......
Eanna
Re: E-Mixers
Post by Eanna »
Excellent, thank you so much for your generosity of time and spirit Roy..
Re: E-Mixers
Looks like fun.
I need to experiential a little bit.
Anyone remember what the stereo feedback module was called?
I need it try something as I'm getting the recurring message.
Yes I am not using the mixers correctly to see that message, which is why I want to try something.
David
Re: E-Mixers
Post by David »
Genius at work. Many thanks
Re: E-Mixers
dawman wrote:Looks like fun.
There's 2 in the folder. Not sure where they came from or if they are what you are talking about.
Feedback.zip
(159.66 KiB) Downloaded 334 times
Re: E-Mixers
Ankyu.
Marco
Re: E-Mixers
Post by Marco »
Works Phantastic! Looks great! Love the colors! Better overview.
roy thinnes
Re: E-Mixers
I'm glad that you like it!
And if there's any uncertainty how to connect the various in/outputs of the mixers, just take a look at my site.
Re: E-Mixers
Nice.
I need to re do my resolution like that..
Marco
Re: E-Mixers
Post by Marco »
Yayajohn where can I find and download the 1-8 fx rack device you used in your example! You are an excellent expert!
Re: E-Mixers
roy thinnes wrote:I'm glad that you like it!
Thanks for the info link RoyT.
faxinadu
Re: E-Mixers
Post by faxinadu »
awesome work! thanks a bunch as always mate! 8)
http://www.oceanswift.net
Music
Spielraum
Re: E-Mixers
Post by Spielraum »
:roll: FETT
