How can I route insert FX in the mixer to an external hardwa
Marco
Post by Marco »
How can I assign an insert FX within a mixer routed to an external effect device e.g. An compressor 19 inch hardware?
Re: How can I route insert FX in the mixer to an external ha
Post by JoPo »
External devices modules, tool menu.
More specifically:
Tools - External Devices - External Effect (M,S or Master)
Connect your inputs - (i.e. ADAT A DEST 1&2)
Connect your outputs - (i.e. ADAT A Source 1&2)
yes that is confusing because it seems it would be the opposite but just focus on what connections drop down when you click on it.
Rename the module
Save the device to your Stereo Effects folder.
Now when you load that device into your insert it will make the connection.
Marco
Post by Marco »
this helps thank you very much for hint :D
You saved a bigger piece of my life time instead of wasting by searching for the answer!
Marco
Post by Marco »
This was the right description, thanks for that fast answer. Successfully tested. Now I implement all my external gear into scope and get the best of all worlds together :D
yes this is a great feature of Scope that i just recently wrapped my head around. Thanks to others here on the Z that helped me out I have 10 different external effects that I can load. And thanks to Roy's CWM 16stereo-4aBus FB mixer i can use them in parallel or serial. Multi flexible!
Marco
Post by Marco »
When you call up the device, you can make your settings and the device has a save icon looks like an old charming diskette, press and save as a new device!
This is a really amazing way to integrate external gear!
