Not sure if this is the right place for this thread but thought I'd start here
Are there any Samplitude users around here that have upgraded to X3? I upgraded yesterday and had an immediate problem. X3 is not recognizing my Scope ASIO drivers. I can't get past the install/configuration process. I get a error message saying something to the effect that Sampltide can't find any ASIO drivers or they weren't loaded in the Scope project.
Samp X2 works fine. In fact I installed Reaper (just as a test) and that worked fine too. I assume it's an X3 bug but wanted to see if anyone might have been successful in installing and using X3. That might shed some light on all this.
Magix has been contacted and I am waiting for a response from them too. Could be a while though lol
Samplitude Pro X3 Suite/XITE Scope problem
Re: Samplitude Pro X3 Suite/XITE Scope problem
Try VoiceMeeter. It solves a lot of ASIO issues with DAWS, Native and Scope.
before starting Samplitude, right click on the sam icon and choose "properties".
on the compatibility tab, check the box to run in compatibility mode and choose win7 or win8.
it should work normally after.
-gary
-gary
That actually worked. Umm.... how did you know to try that? lolol I mean... why did Reaper install and work without me having to do that? Even Samp X2 worked OK.garyb wrote:before starting Samplitude, right click on the sam icon and choose "properties".
-gary
Anyway.... it worked! Thanks Gary!
Never mind Gary. Ironically, after having done this, I went to the Magix/Samplitude user forum and within seconds found a thread already devoted to this exact same problem. The solution posted there is exactly what you described. Don't know how I missed it before - guess I wasn't thinking or forgot to do a search over there. Anyway... that seemed to have solved the problem for XITE users over there. Thanks again
Nothing escapes the eye of GaryB.
I was bitchin' about how I couldn't learn songs from a YouTube list as I like to play along on synths and samplers trying to cop the sounds too.
GaryB said try 44.1k as the project sample rate...
Problem solved.
He's a trained professional in the highest order.
Problem solved.
Hey Gary, waiting for your warm and fuzzy "
", that is the happy ending to many a thread!
lolol yeah it's never really finished until we get a GaryB happy face.
