WTB: Whipcable for PulsarI
FernandoHood
Post by FernandoHood »
Want to buy the Whipcable for Pulsar I
please.
Shipping to Portugal
Ocean Swift Synthesis - Scope 3rd Party Plugins
http://www.oceanswift.net
FernandoHood
http://www.fernandohood.com
Atom Sessions - Music
https://atomsessions.bandcamp.com/
FernandoHood
Re: WTB: BackPlate for PulsarI , II
bump....rly needing this...
FernandoHood
sunmachine
Post by sunmachine »
Hi Fernando,
what exactly are you looking for?
Just the breakout cable or an I/O plate with breakout cable?
The I/O plate can only be used with a Pulsar 2 card as far as I know.
And if you're just looking for the breakout cable you have to get one that matches your card, i. e. you can't use the XLR version if your card was made for the RCA one and vice versa!
faxinadu
Post by faxinadu »
im not sure thats true, you should be able to use either
Music
sunmachine
faxinadu wrote:im not sure thats true, you should be able to use either
There are several threads here where it's being said that the cable whips are not interchangeable due to the different signal levels.
See here for example:
http://forums.scopeusers.com/viewtopic.php?f=5&t=18154
http://forums.scopeusers.com/viewtopic. ... 42#p304742
So, I'd stay safe and use the matching cable whip! :)
FernandoHood
i have one exacly has the one in the picture for PULSAR II,
What i need now is for Pulsar1, would preffer XLR I/O.
well iam also not sure about if needs to be xlr or rca...
BUT Ican test tonight that breakout cable w/ XLR I/O in pulsar1 and see if it works..
FernandoHood
sunmachine
FernandoHood wrote: well iam also not sure about if needs to be xlr or rca...
Maybe you should ask Gary if there's a risk to damage the card by using the wrong cable... better safe than sorry! ;)
no risk of damage that i know of....
but there's also no advantage over using the right cable with an adapter.
changing the cable whip won't balance the signal, nor will it change the level from consumer to pro or vice versa.
you really DO need to use the correct cable with the i/o plate that you have.
faxinadu
Post by faxinadu »
well yeah you might get "wrong" levels but that is probably the only issue. midi and digital i/o should be no problem for sure. and also the level issues, not that big of a deal for most operations i guess, no?
Music
well, the only advantage to using the XLR whip is that the connectors allow a balanced, pro-level signal. the problem is that the Plus Plate has an extra IC to balance the signal, so the XLR connection won't be balanced and the level will be super, super low for any hardware that has an XLR input. there is ZERO, absolutely no advantage to the XLR over RCA in that case. in fact, it's the opposite. you'll need WAY more gain to get the levels up to where they should be and that will add noise. an XLR to RCA adapter will do the same job as a new whip, basically nothing.
you need the whip that matches the plate.
FernandoHood
Re: WTB: Whipcable for PulsarI
thnks guys!
Ive edited my initial request, what i need is just the Whipcable for Pulsar I :)
FernandoHood
my guess is that you'll need to make one.
dante posted the needed info on his site:
http://www.hitfoundry.com/issue_15/dsub_mst.htm
he has XLR and RCA versions posted with pinouts.
FernandoHood
got a Whipcable from Faxi Nadu, THE MAN, Faxi to the rescue as usual. :D
FernandoHood
