Bug Reports
Ocean Swift Synthesis Official Support Subforum
Moderators: valis, faxinadu, FernandoHood
faxinadu
Bug Reports
Post by faxinadu »
Please report bugs for Ocean Swift devices only in this topic. Use the following form to report the issue, try to be as specific as possible when describing the bug. There is no need to re-report a bug listed in the known issues list below.
Device:
Scope System (Xite/Pci, number and models of boards):
Operating System:
32/64 Bit:
Bug Description:
Known Issues:
Workaround - assign Gateway to dsp1 or dsp2: Gateway sequencers not updating correctly on preset change - Xite only
FIXED Previous Issues - redownload updated setups:
Ocean Storm sequencers not updating correctly on preset change - Xite only
Formula X + FormulaFX ask for ModularIV registration code.
http://www.oceanswift.net
Music
Liquid EDGE
Re: Bug Reports
Post by Liquid EDGE »
Gateway on xite
You are able to load this device on to dsp#2. It seems to behave correctly when assigned to this dsp.
faxinadu
Re: Bug Reports
Post by faxinadu »
great! happy it works with this workaround and this is a possible path to a full solution, thanks for the detective work mate :)
Music
Liquid EDGE
Re: Bug Reports
How you getting on with step sequencer element on ocean storm on Xite?
Was thinking (not that I know the in and outs of development) could not the step element be switched for a different method (i.e. The adern flexor step sequencer modules work fine on Xite (no dsp assignment needed, so I'm told, I don't own the flexor modular modules) as it uses audio rates, or make the step sequencing element within ocean storm always attach to dsp 1 or 2, or if that's not possible, where does that trancegate bit sit in the audio chain of ocean storm? Could an Xite version of ocean storm be done where the trancegate is separate (almost like gateway) from the synth and just have the ins and outs on the synth (audio in & out, midi re trigger and preset change link) to hook up to the trance gate (which could then be assigned to dsp 1 or 2)??
faxinadu
Re: Bug Reports
Post by faxinadu »
i'll try option one later on today (assiging to dsp 2). will let you know 8)
Music
Liquid EDGE
Re: Bug Reports
faxinadu wrote:i'll try option one later on today (assiging to dsp 2). will let you know 8)
Ok
Fingers crossed.
Liquid EDGE
Re: Bug Reports
Re: Bug Reports
Fingers crossed = in hopeful anticipation
many places use finger crossing for sealing good fortune.
or something similar...
faxinadu
Re: Bug Reports
Post by faxinadu »
please be patient mate, the fix is not as easy as it might have seemed.
the whole idea of taking the trancegate out of the storm chain is out of the question and so is the idea of making a brand new sequencer based on ramps.
if we can get it to sit on dsp2 then we will provide this, so far it isn't behaving right when doing this. things are being looked at.
Music
Liquid EDGE
Re: Bug Reports
Cheers for the update and clarification. :)
Just out of interest, where in the chain does that trancegate sit? On the master volume out?
faxinadu
Re: Bug Reports
Post by faxinadu »
before the stereo fx
Music
faxinadu
Re: Bug Reports
Post by faxinadu »
fix incoming :)
Music
Liquid EDGE
Re: Bug Reports
faxinadu
Re: Bug Reports
Post by faxinadu »
Ocean Storm sequencer bug on Xite fixed! Xite users please re-download:
ftp://sonic-core.net/software/3rd_party ... -_xite.exe
Music
Liquid EDGE
Re: Bug Reports
Excellent news. Will test it out tomorrow evening.
Thanks faxi. :)
faxinadu
Re: Bug Reports
Post by faxinadu »
yap let me know how it performs for you now
Music
Liquid EDGE
Re: Bug Reports
Works perfect!
Nice one faxi your the man.
wonderful synth!
faxinadu
Re: Bug Reports
Post by faxinadu »
great to know all is smooth 8)
Music
t_tangent
Re: Bug Reports
Post by t_tangent »
Yes, thanks for the Ocean Storm update fix, the sequencer works great now on XITE.
Thank you also for the new Hello Perc device, and the other recent updates. Great stuff.
Merry Christmas faxi, and thanks again for all your hard work and support :)
faxinadu
Re: Bug Reports
Post by faxinadu »
thanks man!!! wait till you see the other holiday release we have incoming... :)
Music
