reason 9.1 wont work with scope 5.1
Manomars
Post by Manomars »
I tried to run reason with Scope 64 bit on 2 systems and it wont work exept for running in rewire mode in cubase 7.5
Does anybody here have this problem or solved it?
Scope does run fine only have a bluescreen with samplers
Re: reason 9.1 wont work with scope 5.1
Are you talking the Reason samplers or the Scope STS samplers?
STS samplers no workey on 64bit :cry:
Manomars
Post by Manomars »
The scope samplers take me to bleu screen IRQ not equal or less
The real problem reason wont work.
Here in the forum some guys use Reason 7 and 8 so i could make it work.
Manomars
Post by Manomars »
Solved
I used system configuration ->advanced boot option and used PCI lock
Then i isolated the IRQ of the pulsar on 11 and killed everything what shared that iRQ
Edit: half solved, the problem has something to do with the asio. I have to delete asio source or restart scope or restart reason randomly to get it working
did you try the patch?
ReasonASIOWorkarounds.20120712-1144.zip
(1.95 KiB) Downloaded 118 times
Manomars
Post by Manomars »
No, i didnt,
Thank u very much Gary!
Will try this tonight.
Manomars
Post by Manomars »
did work out fine
good!
