Sine OSC with phase shift option or cos osc
DragonSF
Post by DragonSF »
Do we have an osc, where I can either select sin or cos or do an arbitrarily phase shift? I need this for my resynth project.
faxinadu
Re: Sine OSC with pahse shift option
Post by faxinadu »
no :/
only place in scope with that is via flexor oscs in modular at the moment. but hey, build it mate! not just a sine, all shapes with phase input would rock in sdk
http://www.oceanswift.net
Music
DragonSF
Re: Sine OSC with phase shift option
Post by DragonSF »
As soon as the dongle arrives consider it done!
you need a dongle for that?
DragonSF
Post by DragonSF »
Yes, I have to create an osc in dsp. Not possible else (I think). Please correct me, if I'm wrong.
Reason: I need 32 of those, do this on the PC will not work in real time.
there are a bunch of oscs in modular.
DragonSF
Post by DragonSF »
Not any one with phase shift option (AFAIK). I need one either sin or cos waveform (dynamically changeable).
why not take an existing design and add the phase shift?
i'm pretty sure that what you want can be realized without any special code.
DragonSF
Post by DragonSF »
If there is a phase shifter, which is voltage controlled (i.e. controlled by the frequency of the osc), that would be fine. I haven't found one.
Though I found one Modular osc, which can produce either sin or cos. I have to dig deeper into that (i.e. if it doesn't consume too much DSP).
control is control, isn't it?
i think it's doable, but of course, i'm not a developer...
DragonSF
Post by DragonSF »
yes, it's definitely doable, provided the phase-shifter as such is available (not to be confused with a phaser). Even a variable delay or allpass filter can be used. But all these are atomic functions.
sure, but they exist afaik.
DragonSF
Re: Sine OSC with phase shift option or cos osc
Post by DragonSF »
I found out, I can use the complex sine osc with a 2:1 switch.
cool!
faxinadu
Post by faxinadu »
can you explain that? what do you mean use it with a 2:1 switch?
Music
DragonSF
Post by DragonSF »
faxinadu wrote:can you explain that? what do you mean use it with a 2:1 switch?
For resynthesis you need either sin or cos signal. The atom has 2 outs (sin and cos), so you need a 2:1 (sin or cos-> next stage). This can be switched dynamically (async).Ecample:
PArt OSC.png (28.11 KiB) Viewed 23481 times
faxinadu
Post by faxinadu »
very nice!!!!
Music
DragonSF
Post by DragonSF »
Thanks.
And this is the result:
DragonSF
Post by DragonSF »
And that's how it sounds (tanpura profile)
cool!
