Midi Note Select
mausmuso
Midi Note Select
Post by mausmuso »
A new Midi filter device for you.
it was suggested by 53E7 way back in 2013.
It is quite simple.
You can select/deselect notes across 88 keys by clicking on the LED above each key.
There is also the Midi filter for channels and Note messages.
The Midi Note In readouts show the last note you played.
This will sound (or not) based on whether the Note is selected or not.
its all saveable as presets and you can CC each control for automation if you want.
I have made a couple of presets based on notes from major scales :)
Now you will never play the wrong notes again :lol:
regards
maus
Midi Note select.png (64.52 KiB) Viewed 8379 times
Midi Note Select.zip
(2.89 MiB) Downloaded 351 times
Re: Midi Note Select
Post by JoPo »
Great ! You've almost done a midi chorder !
A midi chorder like in cubase would be excellent for non keyboard players : you play one finger, and it outputs the chord that start at the key played by the non keyboard player finger...
But your device is nice : if I get it, whatever notes you play, it outputs only the ones with the led on, right ? If it works like that, that's a great non keyboard player help ! Just need to create all minor & major scales presets ! Excellent !
faxinadu
Post by faxinadu »
super! thanks man, really useful for me when messing around!
http://www.oceanswift.net
Music
wouterz
Post by wouterz »
mausmuso
Post by mausmuso »
JoPo wrote:Great ! You've almost done a midi chorder !
Hi JoPo
Its not as sophisticated as you suggest.
The Leds merely turn the keys on or off.
It does not transpose 'off' notes to the nearest 'on' note, although that is a thought.
While I built it, I actually have no use for such a device at this time, it was a request from 53E7 that started me thinking about how to switch every key across 88 keys.
I am not sure whether a major/minor scale device was part of the original thinking or not.
guppy
Post by guppy »
Looks fun ! thanks a lot :)
Nice one Maus
Post by jksuperstar »
Possible uses are for reserving some notes on your keyboard for triggering samples, or program changes to a drum sequencer.
Or making all tonic notes across come from a different synth than all other notes? ;)
53E7
Post by 53E7 »
THANK YOU SO MUCH!!!!! THIS IS AMAZING!
mausmuso
Post by mausmuso »
53E7 wrote:THANK YOU SO MUCH!!!!! THIS IS AMAZING!
You are welcome :D
t_tangent
Post by t_tangent »
Thanks maus. Very useful device :)
