Routing window screensets mess with ZARG RD DRUM Solo Button
ARCADIOS
Post by ARCADIOS »
Hi
Solo buttons reset back to default preset value after I press routing window screenset... Happens with all saved screensets :roll:
Re: Routing window screensets mess with ZARG RD DRUM Solo Bu
i doubt if John will fix that. RD drums were made before screensets were part of Scope.
ARCADIOS
Post by ARCADIOS »
Well...
It is not ok.... For a while I thought that it occurred only at CTRL+ SCreensets.. but no.
RD DRUM keeps remembering SOLO/MUTE actions.. at ALL SCOPE SCREENSETS SHORTCUTS/ CTRL-SHIFT AND ALT
Perhaps it can be fixed in SDK
Post by jksuperstar »
Just off hand, can you try assigning MIDI CTL to the solo/mute buttons, and then check if screensets still have an effect?
When I first began studying the SDK, I had some weirdness with GUI elements, screensets, and such. I never understood what I did wrong, but if I remember correctly, MIDI assignments had an effect at the time. It's been so long, I can't say for sure, as once I learned how to do screensets in gui elements, I didn't have the same quirks. YMMV.
ARCADIOS
Post by ARCADIOS »
Yes, I have assigned all 8 solo buttons, and screensets still affect solos
