Updated Routing Devices
mausmuso
Post by mausmuso »
Hi there,
A new/updated set of routing devices I hope you find useful.
This lot has a number of improvements, including presets and midi control capabilities.
I have also added ganging of stereo inputs and mutes for each input channel.
The channel text fields can be dragged to select an output.
You can also click on the LEDs to select other outputs (bear in mind that this only applies until you select another output via the text field, therefore if you need these configurations, save them as presets).
regards
maus
Routing Devices.zip
(4.73 MiB) Downloaded 412 times
Re: Updated Routing Devices
great, thanks maus!
David
Post by David »
These are amazing, thank you
guppy
Post by guppy »
Really nice tools ! thanks ! :)
ronnie
Post by ronnie »
Lean, mean and clean! Thank you!!!!
faxinadu
Post by faxinadu »
awesome!
http://www.oceanswift.net
Music
RecS
Post by RecS »
Thanks mausmuso !
Really necessary !
Nice stuff that looks great too.
Refrochia
Post by Refrochia »
Thank you soo much! Just been creating a new project and needed a midi controlled 1 to 2 switch.
Helped me out massively!
Post by JoPo »
Very useful !
Just wanted to say that on my xite, matrix settings are not saved with the project. Is it normal ?
mausmuso
Post by mausmuso »
Hi Jopo,
Which version of the matrix are you using?
I will check next time I am in the studio
Regards
maus
Post by JoPo »
Hi Mausmuso ! :)
It's the smalest one : the 8x8 (I don't know if the 2 other matrix have the same behavior). I tried to recall the preset with a program change but no luck.
So I assign midi cc to each matrix part I need to set and it works. But it would be much more easier to find the matrix ready when loading the project ! :D
Those matrix are very useful ! I can use them like a small mixer and send any input anywhere !
Thanks a lot, Mausmuso !
mausmuso
Post by mausmuso »
I had a quick look last night and there is something wrong with the presets on the 24x24 matrix.
When I get a chance I will fix them.
I might also reskin them :)
maus
Ladies & Gentlemen..... Maus
Spielraum
Post by Spielraum »
YEP ~~ 1,2,meins !THKS
mausmuso
Post by mausmuso »
JoPo wrote:Very useful !
Hi JoPo,
I just twigged what the problem might be.
The Text Faders clear all the LED's except the number they are set to, so when recalling a project the text fader parameters clear all but their allocated numbers.
I have rebuilt these devices with new panels (see below).
Would you like me to leave the text faders off and so you can only select each LED manually?
That way it will (I think) save the all of the parameters in the project.
My original thought was to be able to move outputs via text fader Midi CC's, but that may not be all that useful?
The devices below all work, but I have a little work to do to finish building the Parameters and PresetLists.
I have added mutes to the outputs and connection info for the inputs, otherwise they are pretty much the same as before.
I will release them shortly
maus
ronnie
Post by ronnie »
Me want dat. Or else me send big feline named Brutus after youse.
Post by JoPo »
This is really nice, Mausmuso ! :)
I think that the best thing to do is to let choice users ! So you could release one matrix of each... In fact, to have the matrix ready on my actual project, I assigned a midi CC to the text number, so it seems to be useful because midi CC are recalled perfectly. Now, settings should be recalled correctly when loading the Scope project... If we had both routing matrix, we would have both advantages, choice and if one uses only one version, one can delete the other..! So I suggest you to release both version !
I can see you changed the colors and button shape, did you ? The gui is even more nice on the jpg ! More clear and fresh-coloured !
Don't forget to warn us when ready ! :D
ronnie
Post by ronnie »
Ditto & meow.
Marco
Post by Marco »
:D oh yeah that is cool!
