I'm just wondering, in the context, if removing some ASIO I/O (i.e. 18 instead of 32 I/O) can lighten the bandwidth usage and WHICH ASIO driver should I put in my project... because there are so many to choose: ASIO, ASIO float, ASIO2, ASIO-32, etc.
My system:
ASUS Z-87C (LGS 1150)
1x LunaII, 1xScope, 1xScope pro (first series), with the scope pro not used as I/O because of its PCI band issue.
Cubase Pro 8.5
Windows 7 x64
Basically as normal audio card it works flawless, but if I try to load a synth, to use as external synth, I reach suddently and randomly the PCI limit.
I cleaned the STDM connectors but nothing went better. Should I try to clean also the PCI connectors?
Any opinion and experience sharing is welcome
Thanks.
