ASIO, Cubase 5 and Xite
eric
Post by eric »
I have now installed Win7 64 and Cubase 5 (SX) along with Scope 5.1.2709 x64
I can't get the ASIO output of Xite to connect to Cubase.
When I start Cubase I get this error.
And the other 2 pics are the ASIO setup program supplied with Cubase and the ASIO setup from within Cubase.
Anyone seen this or can suggest what the problem may be?
Asio error.png (18.99 KiB) Viewed 5646 times
Cubase deices setup.PNG (55.95 KiB) Viewed 5646 times
ASIO setup.png (37.91 KiB) Viewed 5646 times
Your mouse has moved. Windows must be restarted for these settings to take effect.
Eric Northwood - Data Recovery Specialist
Re: ASIO, Cubase 5 and Xite
why are you using the DirectX driver and not the ASIO driver?
how about a screenshot of your project?
eric
Post by eric »
I don't think it gave me a choice.
One of those screen clips has "ASIO DirectX Full Duplex Driver" so is that not ASIO?
The first message is when I start Cubase, with Scope already running.
Here is the "project". Just a test setup for Audio out to Cubase.
project test.png (321.95 KiB) Viewed 5642 times
no, that's not ASIO. you need to choose ASIO.
Scope was open before you opened Cubase, correct?
eric
Post by eric »
Hi Gary,
Thanks for taking the baton on this one.
Yes, scope was running when I start Cubase.
So how do I choose ASIO now?
Eric
eric
Post by eric »
Hi Gary,
A bit of RTFM and I have it working OK now.
Thanks for your help.
Eric
Great!
