Hi there,
I am looking for a little advice on SDK issues I am experiencing
- When using the Compressor/Compressor Stereo modules, I note the VU does not seem to work. It is connected to the SC0 pad, but driving it hard shows no indications?
- On occasions I get 1000 Stack errors when using certain controls (eg sometimes using the Ratio control on a compressor, or dragging a Freq node on the EQ module). Is there something that can be done to arrest these errors?
- If I set a module to a particular DSP, will that then limit its use to only XITE?
maus
						SDK Questions
Re: SDK Questions
-try connecting both to the sc and to the main in
-never had those stack errors, you on latest sdk?
http://www.oceanswift.net
Music
Music
Re: SDK Questions
Thanks Faxi,
That worked connecting to both Input and SC.
Fra77x2 has been assisting me off line from Pz.
He suggested I watch the sync/async cabling as that may be giving me the stack errors.
That twigged me to think maybe I needed diodes in certain connections to ensure things work only in the one direction
I will give that a go next time I have such errors.
thanks for the assistance
maus
maus
Re: SDK Questions
The stack error looks like a bug to me on the EQ2 module.
I connect G2, f2, Q2 on two EQ2 modules (connecting the first parametrics works as expected)
Adjusting knobs and the Graph node on the top channel is fine.
As soon as I touch the Graph node on the bottom panel, I get 1000 Stack errors.
Hopefully someone replicate or debunk what I am doing.
Re: SDK Questions
what if you adjust it from the knob and not from the node, still errors?
Music
Music
Re: SDK Questions
Wow logged on tonight and can't replicate it!
In the end I folded two EQ's and deleted the troublesome panel and saved.
All is working now as expected.
maus
maus
