Delay for radical panning
Post by JoPo »
Just assign the same cc you use for mixer pan to the 'constant B' module. You can compare dry/wet with the stereo switch just before audio outputs. Put that patch simply in the stereo signal you want to modulate its pan, at the mixer input.
dly pan.jpg (87.67 KiB) Viewed 20630 times
When left panning, it delays right and with right panning, it delays left from 0 -> 12ms.
Light Delay for panning.rar
(534.88 KiB) Downloaded 614 times
Re: Delay for radical panning
Cool.....
I got plenty of panners to test it with....
Hurry up and learn more stuff so you can teach me...
Post by JoPo »
Do you get some good result ?
Here, it work very well, especialy with a continuous pan modulation. With the stereo switch, you can compare with & without the little delays.
