iMonitor
mausmuso
iMonitor
Post by mausmuso »
Hi There,
A simple little device - my first SDK attempt :D .
It provides quick switching between a number of states that are useful in mixing and mastering
- Stereo/stereo reverse
- Mono
- Mid or Side
You can also switch between speakers and phones (or a second set of speakers) or have them both on.
Some like to mix in mono on one speaker so you can mute left or right.
I have tested it on both XITE and PCI and seems to work as expected.
Hope this ise useful to you?
regards
maus
iMonitor.zip
(199.21 KiB) Downloaded 274 times
Ambient Source
Re: iMonitor
Post by Ambient Source »
Thanks, looks useful !
Re: iMonitor
Really nice of you MM.
I think this really cool.
I am hoping it has MIDI CCs.
During gigs muting selected outs with a single CC is highly desirable.
Ankyu
guppy
Re: iMonitor
Post by guppy »
Thanks ! :)
mausmuso
Re: iMonitor
Post by mausmuso »
dawman wrote:Really nice of you MM.
Ankyu
No Midi at this time.
Mainly designed for studio quick monitoring checks during mixing and mastering.
I am thinking about a routing matrix as my next project.
Midi CC would be good in that area.
Re: iMonitor
nice device. Thanks
I would very much like to see a routing matrix.
Yogimeister
Re: iMonitor
Post by Yogimeister »
Looks nice -
I was actually looking for exactly these functions today ... :o
Thanks !
Sounddesigner
Re: iMonitor
Post by Sounddesigner »
Thanks for the freebie!
medway
Re: iMonitor
Post by medway »
Hi thanks for sharing this, looks interesting. Is it possible to create an encoder and decoder? Right now I accomplish this with MSED from Voxengo wrapped around my hardware insert in Cubase.
The problem with this is that it takes two extra slots within Cubase's limited 8 slot limit. Would be great to do this all in Scope instead.
EDIT: see there is already a device here for what I need but will be using this one too, cheers.
mausmuso
Re: iMonitor
Post by mausmuso »
[quote="medway"]Is it possible to create an encoder and decoder? quote]
I am pretty sure there already is a number of MS encoder/decoders floating around in the free domains.
I tend to use the excellent device from 'Digital Audiosoft' - Dynpara MS.
It has fx inserts for ms and has dynamic eq boost/cut capability which is brilliant.
iMonitor was never meant to be any more than to sit in the output of the mix to allow quick switching to the various states as a check, as well as support for mono mixing.
regards
maus
