It's even the opposit : I'd like some pro to explain some of its secrets. There are some parts I already understand but other are unknown language. Like :
- [Load] - What is "align surface" ??
The [SFP] part looks like it's about x - y geometric landmark placement and size of different objects...
Basically, I'd like to know if, by tweaking the Cset file, it would be possible to inverse main and second screen. I explain : I use 2 monitors, I set up the one on my right as main monitor for some important reasons (so I need to keep it like that) but... As it's the main screen, each time I open any project window device, the interface appears on the right monitor, and I'd like it appears on the left !
If there is a way to change that, I guess it's in the Cset... But which part ? If anyone knows, please, tell me ! Help ! Life is so hard ! Thank you !
