Ocean Swift - Wind Filter Plus - FREE DEVICE
faxinadu
Post by faxinadu »
Three resonating bandpass filters in series. Functions as either a standalone filter or as a
filter based synth. Choice of output from the first, second or third filter in the chain.
Filter Controls
3 bandpass filters in series each comprising of:
Gain: Input gain before the filter. 0db change is set on the center position.
Cut: The cutoff point of the filter.
Res: The resonance of the filter
KBT: Keyboard tracking of incoming midi note information.
LFO: Modulation amount from the filter's dedicated LFO.
Mod: Modulation amount from the Aux LFO.
Drive: Distortion amount after the output of the filter.
LFO
Each filter has one dedicated LFO while the Aux LFO is routed to all three filters and can
modulate each one via the Mod knob on the filter.
Wave: The waveform of the LFO. The wave is a choice between a sine, square, saw up,
saw down, triangle, and random - 6 shapes in total.
Rate: The speed of the lfo when not in sync mode. From 0.01 to 400hz.
Div: The speed of the lfo when in sync mode. Measure divisions based on the device's
BPM setting. Provided are 19 divisions: 64bar, 32bar, 16bar, 8bar, 4bar, 2bar, 1bar, 1/2p,
1/2, 1/2t, 1/4p, 1/4. 1/4t, 1/8p, 1/8, 1/8t, 1/16p, 1/16, 1/32.
Phase: The starting phase of the lfo. Noticeable when the LFO is in retrigger mode.
Mild: Tames the lfo's waveform. In general only useful when the Random waveform is
selected in order to avoid clicks (smooth the steps).
Sync: Turns sync mode on and off.
Retrig: Retriggers the osc to start at the point specified by the phase knob with each new
midi gate.
When in sync mode, the divider will let you set really long times, up to 64 bars. Take into
consideration that the Scope system can not go lower than 0.01hz. Very low bpms
coupled with long division times can result in the LFO not going slow enough to be in sync
with your tempo.
Main Controls
Input/Noise: Changes the functionality of the device. In input mode serves as a filter
processing incoming audio. In noise mode serves as a noise and filter based synthesis
device.
Out Select: Switches the final output between that of the first, second or third filters.
Out Gain: Overall output gain. This knob is not saved in presets. 0db change is set on the
center position.
Env: Changes the functionality of the device. With Env turned off the device is outputting
at all times with no amp envelope. With Env turned on the device passes through an amp
envelope controlled by incoming midi gates and the ADSR knobs. Note that even if the
Env button is set to off, the filters still respond to keyboard tracking.
Main Midi: Selects the main midi channel for the device. The envelope, the keyboard
tracking and the dedicated filter LFO's Sync all respond to the channel selected here.
Mod Midi: Selects the midi channel for the Aux LFO only.
BPM: Sets the BPM for the synth. This is the tempo from which all the LFO divisions will
divide from.
Download:
xite:
ftp://sonic-core.net/software/3rd_party ... -_xite.exe
pci:
ftp://sonic-core.net/software/3rd_party ... _-_pci.exe
Visit our website to check out our other devices:
http://www.oceanswift.net/
Music
faxinadu
Re: Ocean Swift - Wind Filter Plus - FREE DEVICE
Post by faxinadu »
the download zip includes also the manual and a preset file with a full 128 preset bank, showcasing mostly examples of the noise mode.
Music
just involved in an art movie sound track, could use it well, but this won't work on old version 4 I guess :cry: :wink:
Post by JoPo »
Waow ! Great ! Thanks a lot ! Parser Filter looks awesome too ! Does it have vowel filters ?
I need this instead of a sample.
All other synths are being used so I can't add the Wind and samples aren't what the doctor ordered.
It's the old Steve Miller version of "Fly Like An Eagle."
I got the Hammond B3 parts dialed in, Solaris and Code 4 + Zebra2 HZ are all busy...
This would be perfect as I have to have a Tape Delay carrying all sounds, no interruptions of a preset change can occur.
ANkyu.. :wink:
faxinadu
Post by faxinadu »
hubird wrote:just involved in an art movie sound track, could use it well, but this won't work on old version 4 I guess :cry: :wink:
hey mate i didn't check, but try!
Music
Sounddesigner
Post by Sounddesigner »
Thanks for the freebie!
faxinadu
Post by faxinadu »
cheers amigos, every now and then we will release a something for free too from the things we are working on :)
Music
sunmachine
Post by sunmachine »
Thanks for this beauty! :)
I've added it to scopeportal.com
faxinadu
Post by faxinadu »
grrrrrrrreat^
Music
I didn't get an email yet assuming there was a download link.
Is there a download link....?
Perhaps I try another browser..?
ANkyu.
mausmuso
Post by mausmuso »
Go to:
Click on products page
Click on Wind Filter
Free download link is there!!
faxinadu
Post by faxinadu »
hey guys! download link is down at the moment, we are fixing some stuff on our website server, will be back there later today :)
Music
faxinadu
Post by faxinadu »
so, apologies, it is back up now!
Music
I tried again but the only Wind I am getting is from my farts.
faxinadu
Post by faxinadu »
sorry again jimmy! we have been setting up for the future the directories, NOW correct link:
xite:
ftp://sonic-core.net/software/3rd_Party ... -_xite.exe
pci:
ftp://sonic-core.net/software/3rd_Party ... _-_pci.exe
Music
Got it finally and thanks, I shall see if I can use it in my live project.
Well I don't have it.
I have a preset only for Wind Filter Plus.
The installer goes to the XITE-1 folder, and I use unusual folders so maybe it doesn't know where to go...?
I then search all folders and do not see the Wind Filter.dev or.mdl.
I even went and created another folder Plug Ins.
Reinstalled the .exe and still nothing except the question on over writing the preset file...
ANkyu..
faxinadu
Post by faxinadu »
it should be in /plugins/oceanswift/
no luck? :0
Music
