connecting pulsar to Cubase 6
ExcelMusicStudio
Post by ExcelMusicStudio »
I run XP & WIN 7 ... as two operating systems..
on XP I run 4.1 PCI
on WIN 7 I now run 5.1
I installed PCI 5.1 on WIN 7 ,,, & got it set up... imported keys
my old Cubase,, 5.2 VST...also on WIN 7 plays back audio ..
media player also works.. as well as Wavelab ..
but my Cubase 6 version .. which is a completely different program..to VST
doesn't play back the audio .. I can see it in the monitor meters... but no sound output ?..
I have searched the forums ,, & can't find any relevant info..
which driver should I be synching everything to ?..
cheers Jules. Excel Music Studio ..
Re: connecting pulsar to Cubase 6
Post by JoPo »
You should check the routing in cubase : vst connection, I/O ; in the device menu., Check if the right driver (Asio-Scope, in this case) is selected in the audio vst system window.
When you update cubase, you can copy the cubase application folder of the ancient version to the new one, like that, you keep all your environment, presets, shorcut, etc... You'll find the application folders in the start menu.
i hate dual boot machines. there are so many stupid places that things can go wrong...
be careful of sharing projects between the different versions of Scope. you don't want the v4 project looking for files in the v4 folder when you're using v5 or vice-versa.
ExcelMusicStudio
YES !>.. FOUND IT ... I dug around in Cubase.. device manager .. hidden away in a sub menu .. isn't it always ?.. got it connected.. thankyou..
I need a dual boot machine,, because some of my old programs won't run on WIn7 ... Doh ..! & some of my new programs won't run on XP ... duh !>
great!
