i7 6700k
i7 6700k
Newest Windows 10 Build.
ASRock Z170M Extreme 4
Intel i7 6700k @ 4.4GHz w/ 120mm Radiator
64GBs Corsair Vengeance LPX
MyDigitalSSD 512GBs x 2 (110,000 IOps)
Samsung 950 Pro NVMe M.2 SSD
650watt CoolerMaster PSU
CoolerMaster N200 mATX Mid Tower
Bidule ASIO Host
PLAY
Kontakt 5
PianoTeq Pro 5
Zebra2 HZ
Omnisphere 2
48k / 64 samples @ 1.2msec.
Solaris
FS1r
SE Code 4
HX-3 Organ Module
TC Fireworx
WINDOWS 10 PRO 1224.jpg (306.74 KiB) Viewed 1050 times
as ssd.jpg (129.48 KiB) Viewed 1050 times
Re: i7 6700k
1 problem left to solve.
I drug folders from Scope XITE-1 windows 8.1 into windows 10 program files folder.
Saving anything goes nutty with chinese writing then says error.
Then wants to save to C/: Users/James folder...?
Guess I can spend hours rebuilding everything from internet and from scratch...... :oops:
Re: i7 6700k
try rerunning the Scope installer. it won't overwrite user files.
Re: i7 6700k
As usual you were right.
For guys who dont like or think they need the manual like me,
M.2 devices use serious bandwidth.
They disable other SATA III Ports when used.
Best to install a boot drive first and if you read the manual place it on a port that wont be
disabled.
Then add the M.2 and only aftef it works put in the 3rd drive.
Ankyu
