I installed SDK 5 64bit on windows 10... but it says cannot
I installed SDK 5 64bit on windows 10... but it says cannot launch the application
Re: I installed SDK 5 64bit on windows 10... but it says can
did you try win8 compatibility mode?
yes.. but didn't work
also when launching scopeSDK.exe it always asks for registration which I do successfully by loading Scope 5.1 keyfile..
and then pops the "cannot launch the application"
well, it was never meant to be used in win10, but i don't see any reason for it not to. it's probably something else....are you running it "as administrator"?
neither that helped
- sunmachine
Just to be clear on this one. So you have the SDK key(s) in that key file?ARCADIOS wrote:also when launching scopeSDK.exe it always asks for registration which I do successfully by loading Scope 5.1 keyfile..
no, i have the scope 5.1 key which says import succeed....
It'll succeed in importing, as you'll then have the right to use your paid-for devices in the SDK. However, you also need the SDK key, which GaryB can help with.
Is that correct GaryB? You want md to send you request string of SDK?
yeah, you need the SDK key. normally, it's 98 euro....
can I use my old SDK?
what old SDK?
write me at support. send me your old SDK key and serial number.
sure.
now stop rolling your eyes at everyone.
Garyb thank you so much.... it is the fastest response someone could expect from technical support!!
It works with the key you sent me...
SDK loaded.
Last question.
How do I use SDK?
SDK loaded.
Last question.
How do I use SDK?
John is a developer who is Sur-Audio Lab. he gives lessons and has made some videos to help get people started.
http://forums.scopeusers.com/viewtopic.php?f=21&t=34177
