yes i known that's not a creamwre hardware.
but i'am using protools hd 192 io digital with creamware card in digital insert in protools and i don't have anymore needs with a digidesign hd process card pci-x 133 mb/s.
it's a wonderfull dsp rtas card and it can work on adat 48 khz with scope adat io module easily.(you can many rtas 48 khz 10 nexus 2 rtas easily)
also you can run vst with the blue cat vst wrapper more easily than the fxpansion !
wordclock sync is made by the 192 io protools hardware to feed creamware adat master sync.
the card is working perfectly, i can send you the digitest of the card  for proove it.
you can also using protools for dsp tdm rtas vst station in a scope asio cubase environment and using scope adat aes/ebu spdif 48 khz i/o
i sale it on ebay with paypal for working , sending and paymnent waranty.
i sale it 150 euros.
thanks
phil
