Stereo Pan filter
Re: Stereo Pan filter
Excellent, thank you.
Very useful design.
Very useful design.
Thank you !
great. thanks!
Even more thanks, this will be especially useful!
Cheers,
Cory
Cheers,
Cory
nice nice nice
stereo tools are always welcome
Excellent stuff ! Very original results... Thanks a lot !
A modular version would be awesome !!
I'm just wondering what are the m1 & m2 input ? When I connect some signal into them, I don't get any sound.
And also, the attenuation knob stucks below 50%, but I can enter values between 0 & 50%.. Why the knob stucks at 50% ?
Thanks for the info !
@JoPo
i build it after i checked the fabfilter's "filter pan".
Well about the attenuation below 50%, the stereo spread is asymmetrical.
I didn't have time to make it right so i cropped the parameter.
Use the text field if you like.
The inputs m1, m2 are for modulation signals so to affect the cutoff of the 3 filters.
Yeah ! Great ! Like some side chain input... If all Scope devices had some modulation input like that ! With audio resolution...fra77x2 wrote:The inputs m1, m2 are for modulation signals so to affect the cutoff of the 3 filters.
Here we have a good device that should work perfectly with ScopeSync...
I don't know fabfilter pan.. In the display, one sees the place of the 3 filters in the pan.. Is that it ?
Euh.....
What do you think about making a modular module version ?
That would be nice !
...compatible with module spaceF?fra77x2 wrote:The inputs m1, m2...
sorry, i'm out of town, will check when back...
- spacef_bb_filter_host.gif (8.01 KiB) Viewed 5833 times
No, it's not compatible..
It's not compatible with any insert, actually. You must load it in the routing window.
Yes but put this puppy on a stereo ASIO channel for Rhodes or FM EPiano.
Very cool...
Very cool...
