Scope Windows are hidden&terms outside of the Monitor
Marco
Post by Marco »
Hi, ich got the Problem, my scope Windows are hidden After i got a beautiful uhdtv Monitor tv connected instead of 3 HD Monitors now i cant Load projects....because the livebar is outside of the Window, anywhere on the Dark side of the moon or Monitor
Marco
Re: Scope Windows are hidden&terms outside of the Monitor
Post by Marco »
There is a ini file i cant edit, but what?
the easiest thing to do would be to connect two monitors and move the missing windows into the first window. then resave the project.
another alternative is to use sheepdog:
http://sheepdog.codeplex.com/
i have found sheepdog to be a very useful app.
you can use the cset to move the windows where you want, but that can also make a mess. i don't recommend it.
Marco
Post by Marco »
Thx :)
Post by JoPo »
Wow ! Huge screen ! 8)
Can you tell me what resolution do you have with that screen ? You say you have more things on screen than with 3 monitors ??
Gary is right : when some Scope window are out of screen, just change the resolution to catch them back, put them close to the start menu and when you put back your huge resolution, they should remain at the same place.
Marco
Post by Marco »
3840x2160 Pixel bought today, im absolutely happy with this 55'' fat peep tv
Marco
Post by Marco »
Now i have the faxi nadu pack and the flexor too and the gigant screen :D
And all PCI full with a nice card
I remember having the same from time to time, when switching monitors. If I remember correctly, setting to a different resolution (and later, back) with Scope OS open would tell Scope about the change, and every window would come show on that 'new resolution' display.
Post by jksuperstar »
I think I switched to classic mode (all in one window) then back to standard mode, to get all the windows back.
Dante had a trick of editing a Windows file, but I don't remember it.
Marco
Post by Marco »
Hey Atom man, you have Shows mehr the right was, Resolution changed and Problem sollen.
Thank you!
