Rocksmith audio settings
asktoby
Post by asktoby »
Has anyone had any success configuring Rocksmith to work on Scope with low latency?
I have (I guess) about 100ms latency currently and am chasing my tail adjusting things to get it down.
Re: Rocksmith audio settings
using wave drivers?
try ASIO drivers or ASIO4all with the wave drivers if Rocksmith will use ASIO.
asktoby
Post by asktoby »
Yes, wave drivers.
The software doesn't let you choose which output to use, but uses whatever is default in Windows' Playback Device settings. I don't think there's any way to select ASIO drivers.
The software has an ini file with an audio section. I was wondering if any other Scope users had come up with a good configuration already. This is the best I've got so far:
Code: Select all
[Audio]
EnableMicrophone=1
ExclusiveMode=0
LatencyBuffer=1
ForceDefaultPlaybackDevice=
ForceWDM=0
ForceDirectXSink=0
Win32UltraLowLatencyMode=1
DumpAudioLog=0
MaxOutputBufferSize=0
