Having messed things up by installing Win 7 i might go for the solution to upgrade to Scope 5.1. But, will I be able to install under 5.1 the plugins which I have bought for Scope 4.5, are the keys still valid?
This applies to Transient designer, Attacker, Flexor, John Bowen Bundle, Mojo, Adern Music pak, Softube package, and more, for which I only have 4.5 licences.
Thanks for any help.
Keys for 4.5 valid for 5.1?
Re: Keys for 4.5 valid for 5.1?
It should work. I have keys for 5.0 that work fine with 5.1. I have Zarg stuff running fine on 5.1
-Tom
-Tom
- sunmachine
As far as I know you'll need new keys because Sonic Core changed the key format with version 5.
So I'd write to support and ask if they can generate new keys for you.
- Bud Weiser
v4.5 worked w/ v4.0 keys,- at least for me ...okvinge wrote:Having messed things up by installing Win 7 i might go for the solution to upgrade to Scope 5.1. But, will I be able to install under 5.1 the plugins which I have bought for Scope 4.5, are the keys still valid?
v5.0 and 5.1 require new v5 keys !
yes, you'll need new keys for those devices.
when purchasing Scope, immediately after purchase, write an email to support and attach a copy of your old keyfile showing those plugins. be sure to note your order number. the new keyfile will include those optional devices.
