Loading performance hang.
Discuss the Creamware Noah
jeezs
Post by jeezs »
Hello,
I have a recurrent problem with Noah every week and sometime every day, Noah stop working and send "loading performance..." or even sometimes "loading performance failed..."
So each time I have to re-flash and reinstall all sent with their key.
Please notice that I reinstall pressing simultaneously the "power" button and the "System" button (in Noah recovery Mode, ready for os update via USB
Sometimes It work and noah boot correctly and often it don't I have to repeat the process 5 or 10 times.
I also try to reinstall without using the recovery mode the result is the same, sometimes It work, sometimes not.
The Noah device does this for years .
But even more strange, is , last year Noah has work almost 3 month without crashing.
since then the problem occur again at least 1 / 2 times per weeks.
I suspect a Rom or flash problem?
can anyone confirm or help me?
maybe Garyb?
Anyway many thanks for help
Re: Loading performance hang.
i can't help much, i'm afraid.
maybe there is a loose connector inside....
hard drive failing?
jeezs
Post by jeezs »
What can I do ?
Is it possible to replace the hard drive?
if yes can you help me about the hard drive spec?
Many thanks for your help
it's just an old ide drive.
the only problem you would have is finding a new one that small.
have you looked inside? be careful.
jeezs
Post by jeezs »
Sorry but I don't see any hard drive.
Here are the pics of Noah Ex internal ( both motherboard and expansion board) can you tell me where it should be?
Thanks again.
Capture d’écran 2015-10-29 à 21.24.32.png (1.33 MiB) Viewed 30280 times
Capture d’écran 2015-10-29 à 21.24.18.png (1.17 MiB) Viewed 30280 times
ooops!
i guess it's MY memory that's faulty.
really, i was just grasping at straws.
jeezs
Post by jeezs »
No fortunately it's only Noah memories that's faulty. :lol:
I guess the roms is damage, Is it possible to get a new one somewhere or at least do you know where I can get my Noah repaired?
Does Sonic core can repair it?
tlaskows
Post by tlaskows »
Is there a compact flash card in there? They're basically the same as an IDE hard drive. They should never die if they're the expensive industrial ones...
-Tom
tlaskows
Post by tlaskows »
Oh, Sonic Core does not deal with Creamware stuff. I don't think they have the diagrams/schematics...
-Tom
-or parts....
you can PM jhulk. he has a shop....
jeezs
Post by jeezs »
ok I'll get in touch with him
thanks for all
tlaskows
Post by tlaskows »
Well, you don't have some of the parts... probably the FPGAs or the code for them. If those die, the unit is done. Most of the chips are in production...
And it would cost a fortune to fix something that's not worth a lot these days.
-Tom
