WIndows 10
emotive
WIndows 10
Post by emotive »
I just installed Scope on Windows 10 and it did not require me to do anything special it simply installed :)
In the past I have had to disable driver signing albeit temporarily I believe but this time I needed only to install and authorize.
No question really but if this is expected behavior then it is very pleasing.
Installed C7, and it picked up the driver, all the i/o was present in devices and I did a quick playback of some MIDI/VST and it worked fine.
UAD no issues there either so I now have a hardware console, VST and DSP mixing.
Cheers
tlaskows
Re: WIndows 10
Post by tlaskows »
Good to know that it works! But I will not upgrade from 7, no matter how good Win 10 is.
-Tom
bob4u
Re: WIndows 10
Post by bob4u »
32 bit I imagine...
with 64 bit all samplers and other sinths have issue
tlaskows
Re: WIndows 10
Post by tlaskows »
I'm on 64 bit. Pretty much everything works except for anything that uses WAV files as oscillators.
-Tom
bob4u
Re: WIndows 10
Post by bob4u »
tlaskows wrote:I'm on 64 bit. Pretty much everything works except for anything that uses WAV files as oscillators
:o are you telling me that you were able to use samplers (e.g. STS 5000) in windows 10 64 bits ???
For the information I have this should be actually impossible !!
I'm VEEERRRY INTERESTED !!
tlaskows
Re: WIndows 10
Post by tlaskows »
No, I'm on Windows 7 and the STS samplers use WAVs so they don't work :lol:
-Tom
miditech
Re: WIndows 10
Post by miditech »
I update windows 10 64bit, my Scope 5.1 not work when play mp3 or movies. no sound. Then i turn back to Windows 8 64bit
Re: WIndows 10
with win10, you must first restart two services, "Windows Audio" and "Windows Audio Endpoint Builder".
go to Run and type "services.msc". find the two services on the list and right click and choose "restart". wave drivers will work after.
Ripper
Re: WIndows 10
Post by Ripper »
garyb wrote:with win10, you must first restart two services, "Windows Audio" and "Windows Audio Endpoint Builder".
Please, please, please, make this a sticky or something of that sort!
THANK YOU Master "10 Dan Belt, MacGyver of The Holly SC" GaryB. :D
tlaskows
Re: WIndows 10
Post by tlaskows »
That's why Mr. Gary is the bawse around here :lol:
-Tom
Re: WIndows 10
i got it from someone else....
Ripper
Re: WIndows 10
Post by Ripper »
garyb wrote::lol:
Where is that copyright statment! :o
:lol: :lol: :lol:
Re: WIndows 10
Is this something you have to do everytime you start the computer?
Re: WIndows 10
for most people, no.
just fwiw-
this is not a problem that is peculiar to Scope.
emotive
Re: WIndows 10
Post by emotive »
Thanks for all the replies!
So if I am using 64 bit, I cannot use the mastering tools?
Re: WIndows 10
no, wait...what?
tlaskows
Re: WIndows 10
Post by tlaskows »
The compressors work fine in 64 bit! You'll be fine. Just get an old outboard sampler for sampling :D
-Tom
emotive
Re: WIndows 10
Post by emotive »
tlaskows wrote:The compressors work fine in 64 bit! You'll be fine. Just get an old outboard sampler for sampling :D
-Tom
So can I import 32 bit float wav files and master them in Scope?
I got the 99 euro software deal to use with 3x 6DSP cards.
I would consider Xite but I'm not in a country where it is presently sold and I'd be wanting to use it with a 64 bit OS if possible.
Re: WIndows 10
yes, of course.
the bit-depth of the audio file is not related to the 32 or 64bit operating system. two completely different things...
emotive
Re: WIndows 10
Post by emotive »
Hi garyb,
Just wondering then what I might import a file into.
I tried STS, and while the GUI's appeared and I could load a preset, there didn't seem a place to import any file.
Cheers
