Windows 10 routing window blank
Damian(not Evil) Adams
Anybody running scope on windows 10
Mine works like a drean, no stutrering or crashes, only problem I have is that the routing window appears blank on opening even though the project is loaded. If I create a new one it is fine until closing and re opening.
Any ideas why.
Dell precision 3500
intel W3530 Dual cpu 2.8ghz
10GB
Nvidea Quadro K2000 Video card
Any ideas why.
Dell precision 3500
10GB
Re: Windows 10 routing window blank
Do you have a blank project loading? (Does it load incredibly fast?)
Maybe set a new project as the default/startup project.
- garyb
- Moderator
if the problem persists, please write to support. i might like to arrange a Teamviewer session so that i can describe the problem accurately to the guys who write code.
- dante
Are the menus invisible as well ( eg no way to drag and drop a new module onto the project) ?
- garyb
- Moderator
the beta has worked properly for others...
have you tried reinstalling, or is this a completely new install?
- siriusbliss
So is Win10 a 'seemless' upgrade, or does it demand upgrade / re-install, reconfigure, and pray approach?
Scope drivers are spotted?
ASIO works?
Honestly Scope ASIO drivers in Win7/8.1 have been mostly stable here while tracking, editing, etc. - until some VST or something hangs up Samplitude/Sequoia, and I am forced to totally reboot the whole machine to get the ASIO drivers back.
No amount of trickery switching sample rates, etc. seems to bring the ASIO drivers back.
I've posted this on Samplitude support forum, but crazy Magix seems preoccupied with other priorities.
I also presume they'll just blame Soniccore just like they do RME.
Anyways, so Win10 just magically updates and everything is good?
G
ASIO works?
G
- Marco
Playing betatesters
for less with windows 10, better works with 7, the optimized version to the 5.1 version.
pwhitmaker
So how is the general feeling, does Socpe 5.1 and drivers work properly in Windows 10? (Except for the TS problem above obviously)
Im not sure if I shall update or not. I would like Windows 10 new functions, but I dont want to start messing with Scope and Cubase problems.
fidox
I have upgraded one of my 2 computers from win 8.1 64bit home to win 10 64bit home.
I didn't do clean install , i leaved all other appz and files untouched.
Upgrade went nice and no major changes were made, few modifications and it's almost like back at 8.1
I have here Luna II cards installed , so Scope 5.1 and Cubase Elements 8.
I read at their (steinberg) site that it's not recomended to upgrade (Cubase) yet to win 10, cause there are some issues,
but i read that after i installed win 10 and tried everything, so i can say, that i don't have any Cubase timing issues or similar,
well, so far.
I also have another machine, where i have other creamware cards installed and Cubase Artist 8
and win 8.1 64bit pro.
With this machine i'll wait so far, cause i'm still using few DAS devices in lots of my projects and i don't want to mess with everything right now.
So far, looks good !
Best,
Matej
well, so far.
Best,
Matej
pwhitmaker
Thanks for your answer Matej, it sounds promising.
