Low input
Kee
Post by Kee »
Hi all Im using a Behringer Ultragain mic preamp and my insignal is very low in pulsar I downloaded the vu-meters and when my micpreamp say 0db pulsar says -10db and im sending linesignal balanced.Is there anyone who has a solution?
Micha
Post by Micha »
you can do a project with a mixer (like Dynamixer) in it to control input. Just connect the Analog Source (or SPDIF Source)
and continue to ASIO Dest or Wave Dest, whatever you use for recording. I use Pulsarmixer, because then I can use the Output for the Controlroom in addition to continue to Analog Dest. So I can hear what is recorded. With the faders of the mixers I have then full control.
Happy pulsaring
Micha
Kee
Post by Kee »
But the strange part is that the signal is so low in Pulsar..............If you have a good mic preamp you shouldn´t have to boost the signal in the mixer or?
that is a decent sounding mic pre,but it is CONSUMER grade and puts out a -10db signal at 0vu. PRO gear is +4db. since you have the -10db version of pulsar,you have a good pre for it.just add gain if necessary.don't trip.
Kee
Post by Kee »
I have the Pulsar II plus card is the input on the card -10 or +4 db?
JoeKa
Post by JoeKa »
I use the same preamp, the Behringer Ultragain Pro, and the manual says clearly +4db output...
Kee
Post by Kee »
And the insignal in Asio in to Cubase is so low that I´m wondering if my drivers are right.
Kee
Post by Kee »
My micpre almost peaks and still im only halfway and led in cubase and I routed the analog source direct to the asio dest
JoeKa
Post by JoeKa »
Then maybe your Ultragain is not ok... A few days ago, I recorded some sounds in my place, the mic set up about 6 meters and one corner away from the Preamp and the computer, turning the amp´s output up a little bit and slightly clapping my hands made the input clip LEDs of my A16 flicker (which is set to -12db input damping...)
edit: I did that hand-clapping sitting in front of my preamp, NOT at the mics place.
<font size=-1>[ This Message was edited by: JoeKa on 2001-11-13 14:11 ]</font>
Kee
Post by Kee »
Ok thanks man I will try it with annother mic pre.Do you know if the analog in on pulsar is -10 or +4db?
JoeKa
Post by JoeKa »
Hmm, the "plus" version should be +4db, but i´m not really sure about it.
Is it a balanced or unbalanced connection? Does it use 3 wires (tip/ring/ring on jack connector or so, ie. microphone Shure Beta 58A) or 2?
normally it's -10db, but if you paid for the option, it's +4db and instead of sp/dif digital is aes/ebu
samplaire
Post by samplaire »
I've got another problem with analog ins/outs: the signal coming to the Luna analog in (for example from my cd or dat) is too high resulting in distortion while the Luna out signal is lower compared to the one from my cd or dat. As I use the analog i/o for rehearsal only this probleem doesn't affect my mixes but is anoying. There was nothing like that when I had my previous card - Gina by Echo (or using my friend's audiomedia III). Do you have any explanation for it? I'm just curious.
most of the mixers have a control room volume.use the control room out to your analog outs to your preamp or amp.
samplaire
Post by samplaire »
Thanks for your reply. I don't have any external mixer (when I use my EA1 via analog inputs I can control the device's out gain though) but isn't it distort the inputs before any control in Pulsar? I'm just curious if there are several standards for input/output level via non balanced outputs? Does it depend on a particular measurement method? (I know about -10db for non balanced and +4db for balabced)
Sam Plaire
<font size=-1>[ This Message was edited by: samplaire on 2001-11-15 01:46 ]</font>
well last things first,-10 or -20 are the most common in/out levels for non balanced lines,but this is not written in stone. for input attenuation, you should be able to use the gain control on a mixer in luna.unless you have speaker level going in,you should have plenty of headroom.there is no law in the universe that says that the cd player is putting out 0db or -10db or -20db.it is not pro reference equipment.still, things should be kinda close.
