Is there a way to sell optional plugins?
tlaskows
Post by tlaskows »
I think I have 2 copies of some licenses.
I did try the search, but couldn't find the answer.
Thanks,
-Tom
Re: Is there a way to sell optional plugins?
Registered across different hardware ? eg 2 different cards ?
tlaskows
Post by tlaskows »
Yes, I think so dante. Let me go look at my keyfile.
-Tom
Well, you can sell em of one of the cards then still run them off the other if the 2 cards are in the one system (STDM).
Is that right garyB ?
tlaskows
Post by tlaskows »
I just checked,
I have proTone and Prodyssey on 2 different cards.
The 3rd one is just acting as a booster.
-Tom
tlaskows
Post by tlaskows »
dante wrote:Well, you can sell em of one of the cards then still run them off the other if the 2 cards are in the one system (STDM).
I have 3 Pro Cards all connected together...
-Tom
currently, there isn't a good method of doing this.
in the past, Creamware would take the keys from one card and move them to another, but the process is tedious and runs the risk of ruining the donor card forever. the way it used to work, was that a program was sent to the user of the donor card. when that program was run, it would erase the rom chip on the donor card and then provide a confirmation code. this would give the card a new serial number. then new keys could be made for the donor card and the receiving card. the problem is that if the process fails, you get a brick instead of a useable audio card and the older the donor card, the more likely a brick would be involved. in addition, there is quite a bit of time required for the process. this method just can't be used anymore.
tlaskows
Post by tlaskows »
I understand, no problem.
Thanks Gary.
-Tom
