Hi Xited Ones,
I was using the xite-1 without any problems for years...
But i changed my studio a bit and unplugged the power.
Unfortunately the unit is not coming back to life (the led stays unlit).
So some questions for that :
1.) If you have a HIPRO power supply ? does it have a led and is it on if you use the power supply ?
2.) Is it necessary that the Xite-1 is connected to a pc so the FrontLED gets active ?
any tips are also welcome....
thank you,
Helmut
						Xite-1 dead
Re: Xite-1 dead
The Xite led is active as soon as you turn it on, pc connected or not.
Any power supply with a led which won't make some light must be broken. Your problem is maybe this, your Xite power supply, you can put any other with same or superior amperage features : take care of the voltage (must be the SAME), curent intensity (same or more but NOT less) and the plug dimension/shape. Go to an electronic shop with your Xite one and ask if they have the same or one with same features.
Do you have a voltmeter to check if there is any voltage at your Xite power supply output ? Simple test (!), if you don't have any, it's dead !
It's very strange it is broken just like this. But that can happens...
- Bud Weiser
Re: Xite-1 dead
XITE´s pwr-supply has a LED and it glows always when connected to a power outlet/power strip,- computer up and running or not and regardless whether XITE is switched on or not !klartraum wrote:Hi Xited Ones,
thank you,
Helmut
When XITE´s pwr-supply´s LED doesn´t glow, the pwr-supply is probably the culprit and dead.
XITE, like every hardware device, can be powered up without being connected to a computer to get it´s power LED active.
I never tried because it makes no sense in normal conditions, but it should be safe (for a short try) even the HDMI cable and PCIe card isn´t connected.
						Re: Xite-1 dead
the first step would be to check the power supply.
						Re: Xite-1 dead
Hey,
thank you so much for your fast tips and infos...
yes it was the power supply... it died after 6 years continious work....
all the best,
Helmut
all the best,
Helmut
Re: Xite-1 dead
It freaked me out aswell but I soon found out how to deal with it. It happens when turning the power off for days, it s like xite is totally shut down and it takes time to reload,therefore, you have to turn it off again and wait till you the green led. Dunno if it s done on purpose but it s not in the manual. To solve it , just leave the power button on and unplug the power supply from the power source.
						Re: Xite-1 dead
So glad that your Xite is alive.  Power supply is cheap to replace, Xite is not
-Tom
						-Tom
