minimax and other external modules
jhulk
Post by jhulk »
i have found replacement encoders which work and replacement switches
for the external hardware modules i.e minimax etc
the model that i tested and worked was a 25pulse version with indents 25 per revolution of 360 degrees
i had to repair one recently which had several bad logic chips and 1 bad switch and the encoder was worn
in that he could not increment with the up down keys and the encoder was not performing correctly
Re: minimax and other external modules
good. this comes up from time to time. i'll send them to you....
