Hey there!
Is it safe to connect the optical audio out of a G5 to the SPDIF input of a Pulsar 2 connected in a PC? Of course, I would use the correct adapters. Both computers are plugged into the same wall outlet but I am concerned about some going electrically bad...
Thanks!
Connecting G5 optical out to Pulsar 2 SPDIF
- paulrmartin
- garyb
- Moderator
Re: Connecting G5 optical out to Pulsar 2 SPDIF
yes, it should be fine.
it's good if both machines have the same ground, but that doesn't even enter into the equation if one machine is using optical i/o.
