This is my first bank of 22 presets for the Zarg Solaris V5, built for convenient loading on the XITE-1 platform. Tested on XITE-1D @ 48KHz in a mix/master project.
I would say there are no fillers or exotics here, just functional sounds. The 3 or 4 solo orchestral instruments are a bit weak, so if anyone can help with those, that would be welcome.
Any feedback on polyphony and load times appreciated, although I would say its still better to 'surf' with a low poly (1 or 2), then up the poly once you've got a sound to work with.
Solaris V5 Presets for XITE
- siriusbliss
Re: Solaris V5 Presets for XITE
So how many voices have you got these up to Dante?
And are we still doing the DSP-assignment tricks?
G
G
I get 4 - 6 - no DSP assignments.
Hi Dante, can I use these presets with my PCI Boards 3x15 dsp?
Sure can. Lemme know what you think.
Hey Dante hey Work Perfect. Nice presets, i like them very much
xite-1 here, i can load all your presets with 6 voices@48 Khz without any problems, as usual, first solaris load has been done with 0 voices thein it loads the presets fine and the dsp allocation is 1 voice per dsp.
Tried up to 8 voices with success, but loading times are too much and sometimes it needs to be set back to 0 voices to solve issues.
Thanks all, so on full XITE-1 : 6 voices no probs and problems start to appear around 8 voices.
