I am diving deeper and deeper into mixing in scope .... And the summing was great - but as I started using "inserts"/devices in scope - I came back full circle as individual tracks sound better - but when summing I start getting horrific phase cancellations and mush ....
(I have gone over the long threads about these issues but didnt see anything too relevant in terms of a solution/workflow ....)
My main issue is the VRBs and FX channels (which are native sends in my DAW and feed out to channels in scope).
Having the VRB(and FX) as a seperate channel means that every time I add a scope device to the main channel - I start getting phase effects between that and the VRB/FX (Most noticeable are stuff like crashes and snares ....)
(I know the lowend is another issue - but it seems like less of a problem - because in the case of send FX - I have (for example) the crashes, lead synth and vocals all feeding the VRB - but if I process each channel later in scope - it seems like a real problem/hassle) to go over and sync all the channels - especially if these settings change every time I load the project ....)
Are there any solutions/methods for this issue??
Also, when trying to emulate a 670 with the 660 comps - i connect two mono 660-M to the L and R channels (or in MS mode via MSslot .... Xenon codec doesnt work for me for some reason ... Awesome archetecture - but the sound seems to "drift" from the stereo center ...??!!) - but I am not sure they are in phase (in any case this is less noticeable than the VRB cancellation artifacts in most cases ...)
Any advice/tips would be appreciated ....
(I am running PCI 5.1 - so no SDK or DSP allocation control I think ...)
Thanx
