Stereo Sampler OSC?
YISH313z
Stereo Sampler OSC?
Post by YISH313z »
Any chance for this being created? I have yet to find a stereo wave player, module in Scope.
Or perhaps ive overlooked it.
I miss my STS sampler very much, and the STS OSC just crashes my system.
Has anyone here used the STS OSC successfully in windows 64 bit without the BSOD and muticore CPU?
Im going to run a MemTest on my ram, sadly i think one of my chips is corrupted.(ddr2)
YISH313z
Re: Stereo Sampler OSC?
Post by YISH313z »
Just as I suspected:
I order new Ram sticks so hopefully i can get to use these modules, really miss my Scope songs.
ok, but the older sample oscs and STS do NOT work in 64bit.
i believe that there are newer sample oscs in Flexor that work, but that may not be correct. of course, in 32bit, the sample oscs work correctly.
YISH313z
Post by YISH313z »
i will look/try those, by any chance how important is the Ram timing tables CAS# RAS# to Scope, i just noticed that i have a oddball chip that is not of the same speed and timings as my other chips.
YISH313z
Post by YISH313z »
Well so far so good, with i think is the Flexor Sample OSC though i would have to run it into the ground to see if its stable.
So is there no Stereo Sample OSC available?
YISH313z
Post by YISH313z »
Ah well spoke to soon, locked up on me. I will try again when the new ram arrives.
roy thinnes
Post by roy thinnes »
Flexor sample oscs? :o :o
Did I miss something?
YISH313z
Post by YISH313z »
yep, there is a sample osc in the package.
jhulk
Post by jhulk »
the bc modular has sts sample osc that have stereo outs ang a panning control function
djmicron
Post by djmicron »
roy thinnes wrote:Flexor sample oscs? :o :o
the only flexor module able to load samples that i know is the wave shaper.
roy thinnes
jhulk wrote:the bc modular has sts sample osc that have stereo outs ang a panning control function
yes BCM has five sample osc variations, two of them stereo.
you can load Akai & STS programs, and Soundfont.
But I'm quite sure that it doesn't work in 64 bit though.
djmicron wrote:the only flexor module able to load samples that i know is the wave shaper.
I second that. But maybe Flexor V is out and I didn't get it :evil:
jhulk
Post by jhulk »
my son who is doing design and games
they use a program called oracle where you can run a xp 32 install at the same time as the 64bit
with drivers for both as it works of a separate hd
so that when they are coding it works correctly in x86 and 64bit enviroments and can test between the 2
djmicron
Post by djmicron »
jhulk wrote:my son who is doing design and games
It's a virtualization environment, it's good for coding on multiple operating systems, but it doesn't allow every hardware to run natively.
YISH313z
Post by YISH313z »
jhulk, is that in the updated BC modular version as the 3 sample osc from bc modular i have only has 1 red connection for the output
YISH313z
Post by YISH313z »
disregard you said 'sts sampler osc', that crashed when i tried to use it the first time, ill try again when my ram arrives
STS will always crash in 64bit windows.
Spielraum
Post by Spielraum »
roy thinnes wrote:I second that. But maybe Flexor V is out and I didn't get it :evil:
V?
you have IV??
last:
22.6.2007 FleXor v3 has been released!
http://www.adern.com/home/modules.php?n ... view&id=18
roy thinnes
Spielraum wrote:V?you have IV??
just a joke. there are two Flexor versions - 1 and 3.
Assaf left out V2 I think because so much time has elapsed between V1 and V3.
So next update (which never will come) would be V5, or?
YISH313z
Post by YISH313z »
Is it possible to create a Stereo Sample player in scope?
roy thinnes
With the current atoms - sorry, no.
And on 64bit - double no.
Sorry.
