SC-Plate: how comes no midi control>?
pranza
Post by pranza »
actually i see sc-plate (ex- stw p100) as one of the reasons to own a pulsar
it's so damn good... midi for it is a must! i don't remember if p100 had midi control but it's essential... without midi it's just static, standing still. and all fun is gently twisting parameters...and now it's only via mouse, one at a time...
djmicron
Re: SC-Plate: how comes no midi control>?
Post by djmicron »
use it as insert effect inside a module with midi inputs, such as the multi fx module and you'll be able to assign midi cc's to the reverb.
Here's some cool SDK stuff also.
Midi Hosts.zip
(58.27 KiB) Downloaded 378 times
pranza
Post by pranza »
thanks and thanks!!
ronnie
Post by ronnie »
Sorry if I'm in wrong thread but I searched and wound up here! When I load SC Plate it loads into the project but next time it starts I get like board communications errors and reset sample rate dialogs until SCOPE goes south. I renamed the dev file so SCOPE wouldn't find it and would load the project so I could delete the device from the pane. Running 5.1 on Win 7 64. This is not a show stopper but I heard a lot of good things about SC Plate and would like to give it a whirl.
Warp69
Post by Warp69 »
The Plate use a lot of DSP modules - so Scope can't place all the modules on the same DSP. It would be best to load the Plate before any other devices (especially RAM based devices).
I really like using the BC2x2RP Shell with Plate X.
I can add some EQ or a Filter, plus MIDI, and the Shell is recallable so it pops up from a screenset, and the Plate X and other stock plugs, in it's serial alignment, are all on the screen simultaneously.
Real Nice... :D
