Float or integer ?
Float or integer ?
So ? What is the best for recording ? Asio float source or Asio integer source ?
Maybe they have the answer in coursera.org/audio ?
I'm asking because I thought the best was Asio float source untill I read this :
http://forums.planetz.com/viewtopic.php ... 2&p=303578
But now, I'm not as sure as I wish ! And I confess that my ears don't get any difference... That's why I lightly prefer int values : it's less tiring for computing... But as anyone, I want to record as best as possible.
- garyb
- Moderator
Re: Float or integer ?
neither is best. both have advantages and disadvantages. i would use the driver most suited to the sequencer. if the sequencer was designed to use ASIO float i'd probably use float.with Cubase, i'd use the floating point driver, with Samplitude, i'd probably use integer. if you can't hear any difference, why stress over it?
jhulk
scope mostly use int
float uses more dsp
as it has to convert float to int
float uses more dsp
Thanks for the advices !
Sorry to take so much time for answering.
I think I gonna keep asio integer.. As I don't hear any difference and it's less tiring to compute...
->Garyb, I don't stress over it that much, I just need to feel reassured as I'm far from a pro audio ingineer.
Merci !
Merci !
Music Manic
I think if you're doing a lot of mixing/processing in your DAW you should use float, but if you're doing everything in SCOPE use integer.
BTW which are the float ASIO and which are the integer. Are they labelled differently in Scope?
Software i/o "Asio source" is integer and "Asio float source" is ... float source...
- garyb
- Moderator
the not-very-accurate explanation of the difference is, the advantage to the floating point driver is that it's very hard to clip as there's 8bits of headroom that's not available with integer math. 32bit integer sounds better than 24bit float(more accurate overall), but 24bit float is more immune to digital distortion. both use 32bits.
24bit float sounds pretty similar to 24 bit integer, but 24bit float can handle hotter signals better.
Music Manic
So you can hear it Gary!garyb wrote:the not-very-accurate explanation of the difference is, the advantage to the floating point driver is that it's very hard to clip as there's 8bits of headroom that's not available with integer math. 32bit integer sounds better than 24bit float(more accurate overall), but 24bit float is more immune to digital distortion. both use 32bits.
pwhitmaker
I just discovered that there is a 32 bit float ASIO2 module, and I use Cubase so I want to use this scope module.
But why is there an "ASIO float dest" module, but not an "ASIO2 float dest" module?
- garyb
- Moderator
because that's how the ASIO2 modules work.
- garyb
- Moderator
- spacef
http://scope.zone/index.php?id=57&lg=en
"The SHARC processor dominates the DSP market with exceptional performance and outstanding I/O throughput. Its real-time floating-point processing performs where transparency and dynamic range is key".
Scope designers use integer though.
I personnally use asio 32 bit float (studio one does not give you the choice anyways
(*) not sure it is because studio one detects the loaded asio driver or because it only has float. no idea what is best, apparently it is the same, I trust Gary B.
- katano
ha! maybe OT, but I just installed Studio 1 after years with Cubase and mixing in Scope. And I have to say, it‘s great so far! I guess I‘ll use Scope for bus mixing and mastering and synths only from now on, as the workflow with Studio One, Console1 and Console1 fader is all I ever wanted to have within Scope...
