Components for STDM Cable - Where to buy in germany?
supersam31
Post by supersam31 »
Hello Guys,
if anybody can tell me where I can buy the Components to build an stdm Cable I would be very thankful!!
I can`t find especially the card edge Connector anywhere.
Thanks for your help!
Re: Components for STDM Cable - Where to buy in germany?
Dunno bout Germany specifically - but did you try digikey ?
http://www.digikey.com/product-search/e ... &x=14&y=19
more info here...
http://www.hitfoundry.com/issue_10/stm_mast.htm
supersam31
thanx dante!
yes, I got the link already from the nice sonic core support and will buy it there if there is no other way. But it`s expensive shipping and takes quite long to deliver..
I think I might have found working connectors in Germany (as the cable is not the big problem). It was an 3 hour search yesterday because the serial numbers are different and the connectors are named totally different :-)
When I have tried it and it works I will post it, but if anybody knows exactly which parts are working please write it here!
thanks for your support
any 20pin edge connector that crimps onto the 20wire ribbon cable should work. there are several manufacturers.
jhulk
Post by jhulk »
20 pin card edge connectors
that will bring up the correct type
there are a few wholesalers that sell them try rapidonline they have a german outlet
rs components have them they also have german wholesalers
try conrad also have german outlets
and Reichelt are also in germany
supersam31
I got the right parts and they are working. It`s really difficult to find it in Germany because they are named totally different.
You can buy it from farnell, rs-online (or "eibtron" if you are a private buyer and can`t buy it for your business).
It`s named "LP Kantensteckverbinder IDC" or search for "VERBINDER KANTEN SCHNEIDKLEMM 20POL"
here you have the links:
-http://de.rs-online.com/web/p/kantenste ... r/0471266/
-http://de.rs-online.com/web/p/kantenste ... r/1209983/
-http://www.eibtron.com/epages/eibtron.s ... s/120-9983
-http://de.farnell.com/avx-interconnect/ ... /dp/635730
for the cable you can use any 20 conductor ribboncable (Flachbandkabel) with 28 AWG Wire Gauge (Aderquerschnitt) and 0,127 mm pitch (Rastermaß) -> that is almost a standard, so normaly every 20 conductor ribboncable should work.
hope I can help some german collegues with that!
sunmachine
Post by sunmachine »
Thanks for sharing!
@Dante: Would be great if you'd add the translations and links to your article for future reference. :)
sunmachine wrote:Thanks for sharing!
Done ! Thanx 4 the tip.
sunmachine
Just found something more to add: The official STDM cable construction manual :)
http://sonic-core.net/joomla.soniccore/ ... 56&lang=us
And the same in german:
http://sonic-core.net/joomla.soniccore/ ... 56&lang=de
Linked - with acknowledgement :)
