scope xtc mode fl studio export file no sound
Discuss Scope XTC mode.
heiwa_boken
Post by heiwa_boken »
hello
i have the scope xtc mode in fl studio when I export there is no sound in the file
but when i play the seqencer (fl studio) there is the sound.????????????
ShogunSpy
Re: scope xtc mode fl studio export file no sound
Post by ShogunSpy »
Hi
Scope synths and effects will not work like this. You Have to imagine that Scope synths and effects are like real hardware..that's why they sound so good :)
I Have not used FL so sorry can't help you anymore. If you use SFP mode in scope you can record into VDAT.
in SPF mode, you can 'mix down' your track by routing the final stereo output of the Scope project to ASIO outputs that your host sequencer can use as input to a stereo mixdown track.
YISH313z
Post by YISH313z »
dante wrote:in SPF mode, you can 'mix down' your track by routing the final stereo output of the Scope project to ASIO outputs that your host sequencer can use as input to a stereo mix-down track.
+1
Also if you are using XTC i Believe you can setup your XTC project before hand to output to ASIO but be careful not to have the mixer channel in FLS, that's receiving the asio input, sending to the master in the FLStudio mixer.
