"24 bit wave source" module outputs mono sound
guppy
Post by guppy »
Hello !
I have a problem when loading the "24bit wave source module": sound outputs in mono (only one channel), and normal "wave source" module is working fine on both channels.
Do you know if i made something wrong or misunderstood something ?
As the normal "wave source" module is working perfectly, i'm using it, I don't even know what is the real difference between them (as 24bit sounds can be played with normal wave source), but i'd like to know if there's a known problem, or something i could do to use the 24bitwave one.
The "24bit wav dest" module is working fine as far as I know.
Thanks !
Re: "24 bit wave source" module outputs mono sound
no, it's something on your end. there's no such problem with the wave modules...
guppy
Post by guppy »
hmmm ok
i'm going to investigate it more as soon as i can !
Thanks Gary !
guppy
Post by guppy »
ok, after some research, i just found a solution to have the "24 bit wave source" module with stereo:
I have to load first a wave source (16bit or 24bit, doesn't matter), and only after the 24bit wave source (then called 24 bit wave source 2).
After that, I have to change the wave device default in windows (the 2nd one was default, i had to change it for the 1st one). If i don't change it, foobar is playing well, but not flash.
At least, i can remove the first wave module from Scope, and 24 bit wave source 2 is ok, with stereo.
I don't know why i have to do that, can somebody confirm it with a test please ?
If i let the default windows wave device (the 2nd one), and load only the 24 bit wave source module in Scope as usual without loading before a 1st wave source module, the 24 bit wave source only plays sound in mono (but the 16 bit wave source is working well without any tweak).
only with xite1.
Edit: can somebody explain me please if there's a physical difference when playing a 24 bit wave file with wave source, and 24 bit wave source ? because 24 bit files play well with wave source, so i don't know if it is really necesary to load a 24 bit wave source module for it.
Thanks !
