XTC mode
Discuss Scope XTC mode.
ondas
XTC mode
Post by ondas »
Please!! XTC mode for 64 bit... when it will come????
siriusbliss
Re: XTC mode
Post by siriusbliss »
Probably never.
VSTim mode is also old, and really not supported.
I recommend just routing your I/O out/in to your DAW rather than 'inside' the channels IN the DAW.
G
erminardi
Re: XTC mode
Post by erminardi »
Yes, but how you solve the problem to insert i.e. a VST effect in series in between 2 scope effects, in a channel?
Or viceversa?
siriusbliss
Re: XTC mode
erminardi wrote:Yes, but how you solve the problem to insert i.e. a VST effect in series in between 2 scope effects, in a channel?
Or viceversa?
I don't.
Sometimes ill route my DAW channel (that has VSTs in-channel) out to to Scope effects and back in to another channel in Samplitude.
G
erminardi
Re: XTC mode
Post by erminardi »
UAD is making tonns of money, becoming a truly standard, with XTC concept (with the same technology BTW)... instead, it is normal that Sonicore decides to abandon this kind of project.
siriusbliss
Re: XTC mode
erminardi wrote:UAD is making tonns of money, becoming a truly standard, with XTC concept (with the same technology BTW)... instead, it is normal that Sonicore decides to abandon this kind of project.
Not abandoned, just carried over from 20-year old tech that never really worked very well.
Using Scope as an environment rather than an insert chain is way more flexible anyways IMO.
G
erminardi
Re: XTC mode
Post by erminardi »
G
Good and flexible for synth and experimental composition, but if U need DAW integration and total & quick recall and many other standards, as professionist (people that pay well your work and technology), not so much.
Re: XTC mode
xtc mode was abandoned by CREAMWARE in v3.
it has been retained in v4 and v5, but no extra development was done.
actually, for professionals, i disagree that xtc mode is superior. it's just a convenience for everyone.
Re: XTC mode
yet, a UAD-like S/C DSP card with the main plugins and the topsynths as VSTi would have been nice, ánd a monymaker.
I love my UAD 2 quad card and the way it integrates in my DAW.
pranza
Re: XTC mode
Post by pranza »
for me it works fine under 64bit:
samplitude - must use version not later than 11
cubase - at least v 5 is working
wavelab - not working (device does not correspond...error starting asio in xtc mode)
sound forge - not working (latest version)
acid - working (latest version)
live! - not working (latest version)
