Registry Hack Enables Continued Updates For Windows XP
from Getting XP updates
POSReady 2009 is based on the Windows XP kernel and get updates until 2019. I want to know, if i can apply that on normal XP, but i get a error of version mismatch.
So i looking in the update.inf/update_SP3QFE.inf and it checks only some registry entries:
Code: Select all
[Prerequisite]
    condition=CompositeOp,OrOp,Prereq.XPInstallEmbedded.Section
[Prereq.XPInstallEmbedded.Section]
    OrOp=Prereq.XPInstallEmbedded1.Section
    OrOp=Prereq.XPInstallEmbedded2.Section
    Display_String="%A6Blocked%"
[Prereq.XPInstallEmbedded1.Section]
    EqualOp=CheckReg,HKLM,"System\CurrentControlSet\Control\WindowsEmbedded\ProductVersion",FeaturePackVersion,0x00000000,==,"SP3"
    EqualOp=CheckReg,HKLM,"SYSTEM\WPA\WEPOS",Installed,0x10001,==,1
[Prereq.XPInstallEmbedded2.Section]
    EqualOp=CheckReg,HKLM,"System\WPA\WES",Installed,0x10001,==,1
    EqualOp=CheckReg,HKLM,"SYSTEM\WPA\POSReady",Installed,0x10001,==,1
The solution is simple. Create a text file with this content::
Code: Select all
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001
Save as .reg file and doubleclick to import it.
POSReady2009 Updates will now install on a normal XP and Windows Updates shows also the updates for POSReady2009
ATTENTION: Use it you own risk! These updates are not tested on a regular XP system and could damage your system
see also: Registry hack enables continued updates for Windows XP (zdnet) and Registry Hack Enables Continued Updates For Windows XP (slashdot discussion)
If you happen to be running XP 64bit, check the sebjik.com (first) link for more information...
quantum
Re: Registry Hack Enables Continued Updates For Windows XP
Post by quantum »
If you're doing pro audio you're not supposed to have internet connected to a DAW anyway. :D
And shouldn't you be using an Atari or Amiga also? :lol:
Or maybe you want a current slipstreamed image for your Virtualboxes :wink:
quantum
Post by quantum »
I still do it but just saying it's the ultimate protection from hackers and malware.
