Freeze The pc Only With Xtc ,energyXt Flstudio And The other
Discuss Scope XTC mode.
heiwa_boken
Post by heiwa_boken »
hello
Freeze The pc (windows ) Only With Xtc mode ,energyXt Flstudio And The other
since I updated windows xp pro to sp3.?
__ _ _ _ _ _ _ _ _ _ _ _
my version scope is 5
driver SONIC_CORE_SCOPE_PCI_v5.0.2617_EN.exe
thank you for the help.
Re: Freeze The pc Only With Xtc ,energyXt Flstudio And The o
is automatic updates in windows turned on?
if so, turn it off. since sp3 automatic updates freezes xp.
heiwa_boken
I try to disabled automatic updates.
My computer still freezes
it is only when I execute application (flstudio, energyXT) in xtc mode.
without xtc mode. no problem, I can used (flstudio, energyXT, other)
Post by jksuperstar »
In Ableton Live, I get crashes if I have Multicore/multiprocessor enabled. If I disable that, I do not get any crashes.
I do not know if energyXT has this option, but you should look for it & try to disable to see if that helps.
what's sharing an irq with the Scope card?
heiwa_boken
hello
how can I change irq??
you can't.
you can move the card, you can move the ethernet card(if it is a card) or you can disable the ethernet controller in the device manager.
i'd try disabling the ethernet controller just as an experiment.
heiwa_boken
i try disable the ethernet controller
a question ???
Scope 5 & mode xtc is what works on windows 7 32bit ??
yes.
heiwa_boken
I try windows xp pro sp2 it works.
thanks cédric
